Another Gem
Started by donbj, August 18, 2021, 10:14:13 PM
Al_Smith
I've really never timed them but I think my 2100 and the two Partner P-100's cut  about the same .In theory they should be close as they are the same bore and stoke .As for the Husqvarna it was never popular here so mine is the only one I know of in this area .Compression static is 165 so I think except for the v stack intake with a K and N filter it's stock .I've never had the cylinder off  to check but weather souped or stock it's got enough as it sits .If it ain't broke don't fix it . ;)
donbj
Quote from: Real1shepherd on August 28, 2021, 06:34:07 PMnot my 2094, not your 394 or your 262xp.
I re-read my post and it kind of reads like I think my 262 would keep up to the 2100. I totally meant the 394, just worded it a bit wrong, bad grammer me.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Al_Smith
Not to annoy the Swedish saw afficionadoes but I have a souped up Stihl 038 magnum that will out run a Husqvarna stock 2100 on small stuff .When it gets to above 20-24  inches the contest changes .A saw just like a man has to know it's limitations .That said I like the Swedish saws .
Real1shepherd
That was the point....smaller saws than the 2100/2101 will outrun it easily in smaller timber. Lugging around a heavy 2100/2101 with a smaller bar in smaller timber is a ridiculous waste of a good saw design.
Husky saw a change in timber scale needs in NA and came out with the 394 and then the 395. The 395 stayed popular all this time and is considered a 'big' saw. Now you have the 592 with autotune....if it ever hits the shelves.
Kevin
donbj
"Not to annoy the Swedish saw afficionadoes but I have a souped up Stihl 038 magnum that will out run a Husqvarna stock 2100 on small stuff"
Doesn't annoy me one bit. Have a couple friends that are Stihl guys. This latest 394 cane by horse trading some Stihl stuff for it. They are good saws.
DHansen
Maintenance plays a big role in how good a tool is perceived to be.  A poorly maintained 066 or 394 will annoy the best of us.
donbj
Quote from: DHansen on August 29, 2021, 02:33:13 PM
Yep! I've had saws that spent time airborne back in my younger days.
DHansen
Not trying to drag this thread too far off topic, but I am curious as to what a good condition, functional 394xp is selling for at this time.  It does not appear to have been used hard.  Bar side faces are well worn off from use.  Can't see any paint remaining on the bar.  But no blue or heat indication on any part of the bar.  24" bar.
donbj
Quote from: DHansen on October 02, 2021, 09:43:53 AM
There's a few variables in my opinion. Is the saw all stock or does it have some cheap after market parts that change the picture quick? A friend rebuilt a nice 288 with a cheap Chinese jug and piston and didn't last long.
Around here it would go for around 7-800 Canadian or more if it's a real good one.
DHansen
Thanks for the info.
