Whatcha Sawin' 2021 ??
Started by Magicman, December 31, 2020, 10:05:41 AM
Peter Drouin
Always nice to get out of the sun,
KenMac
Quote from: Peter Drouin on August 27, 2021, 08:56:03 PM
The smartest thing I did was to build a pole barn for my mill. I would not do much sawing at all without it. Of course, I don't travel to saw but it keeps me in the shade.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB, Takeuchi TB260C
Southside
Nice thing with the Super 70 is the optional A/C that is available.  Mine didn't come with one, but I can add it on, need to do that.
SS,
  I don't think you are going to want to add that A/C option on your 70. I understand they are not environmentally friendly and government regulations will be retroactively prohibiting in the near future plus sitting in the 72 degree climate and handling the 98 degree lumber being produced causes your hands to crack. A better option seems to be the new plug in moon suit that not only keeps you cool but also protects you from the sawdust, exposure to irritants like some sawdust and poison ivy and the elements allowing you to saw in the rain and snow. The original model took about 45 minutes to put on and take off and was causing problems with older sawyers with weak bladders and digestive systems but the newest models come with a trap door and free box of depends.
jasonb
Quote from: Magicman on August 27, 2021, 02:19:11 PM
Starting early (6:00) and sawing until it gets hot, then knocking off and waiting until the next day.
I helped my Dad build houses and in the summer this was our schedule when he got older.  Work 6:00 until 12:00 and decide if he could work any longer.
HM122
TimW
Quote from: WV Sawmiller on August 28, 2021, 07:53:58 AM
SS,
WV,
     I think you have snorted too much sawdust.
                       hugs, Brandi
We finished the Red Oak that was skidded to the top of the hill this morning (852 bf) of mostly 1X6's with a few 2X6's, etc.  Total for this job so far is 2686 bf sawn only in the mornings.
And yup as I told the customer, metal in the last log.  Fence wire that cost him $45.
The sawmill is now parked 'under the hill' at his largest log that measures 46" and also has metal.  We will get to it after Hurricane Ida passes.
HemlockKing
Quote from: Magicman on August 28, 2021, 04:32:15 PM
Best of luck MM, don’t forget to secure the bbq and deck furniture lol
A1
Brandi,
  Must have been the mixture of that spalted maple and the red cedar.  :D
Lynn,
   Stay safe and above the water level. I guess it is too late to suggest leaving that log on the mill to keep it from blowing away.
I was happy to finish sawing all of the logs on top of the hill and be able to move the sawmill to the bottom of the hill to that log as a precautionary measure.
We are on high ground here at home and also at the Cabin so no chance of flooding but we could be blown away.  We have many trees that would reach our home; SYP, Red & White Oak.   :-X
caveman
My son in law is at my house now.  In the morning he is headed to Louisiana to deal with storm damage.  He will likely be gone for two weeks.  I asked him if he is taking a second pair of boots, boot dryer, bug dope and extra socks.  Yes to all...not his first rodeo.  I hope y'all come through this blow with minimal damage.
MM, are you charging $45 for a damaged blade now?  I was sawing a do nothing job today for a repeat customer and on the last board I sawed into the clamp.  It was almost low enough.
Caveman
DennisK
Doesn't MM saw by the hour, blade cost and down time probably add up to that.
Quote from: Magicman on August 28, 2021, 04:32:15 PMFence wire that cost him $45.
Quote from: caveman on August 28, 2021, 08:25:56 PMMM, are you charging $45 for a damaged blade now?
Yes, $45 for a metal strike in a customer's log.
In this instance I cautioned him several times that the log had metal and what it would cost.  Fact is, the Oak lumber was much more valuable than the blade cost.
The huge log where the sawmill is parked.....
has metal and I will buck ~4' off of the butt to try to get rid of the metal and also to reduce the 46" log size.  :o
I almost always saw by the board foot rate and I do not charge the customer for incidental chainsaw trimming.  Sawing ERC and timbers is generally hourly rate.
Peter Drouin
Cutting iron is always fun.
And sometimes rocks.
Tom King
You may laugh about that "Moon Suit", but one of my Supplied Air rigs uses a 120v air conditioner for the air supply.  Put the Tyvek hood skirt inside the collar of a Tyvek suit, and I expect that's about the same thing.
Taking the old paint off of an old house was done in the middle of the Summer with heat guns.  I was going to be doing woodworking inside in the air conditioning, but when I asked the guys what they wanted to do that day, as we were driving to the job on what was going to be an extremely hot day,  they said they'd remove paint.
samandothers
Did that make you question their judgement?
Tom King
An air conditioned suit, not having to do a lot of moving around, is not a bad place to spend a hot day, while getting paid.
This morning's sawing began here last week
When my customer showed me this 46" butt Water Oak log that indicated metal.
I parked the sawmill beside it Saturday, and we returned this morning.
The first order of business was to 'jump butt' 5' from the butt and 3' from the top end leaving a nice 12' log.
The log was sorta egg shaped and 36" on both the butt and top end.  The weight calculator shows 5428 lbs. but that would be a log with taper.  This log had none
The Kubota rolled it onto the loading arms and I would take over from there.  The Magic Hook is secured to the log clamp with no slack.
And the loader & clamp working together loaded the log.
So now let the 'gunbarreling' begin.
And continue.
Until I had three 6" cants for the saw through.  Notice that the pith check runs horizontal with the boards.
The heat forced us to quit at 10:30 so we will return Friday to edge the flitches and saw his last log.  It will be interesting to see how many board feet this log yielded.
Lots of riftsawn and quartersawn boards from the two outside cants.
It will all be wall paneling.
The 'other' Oak log that we will saw Friday was brought down by Hurricane Ida, otherwise this big log would have put this job in the books.
It is forecast to be cooler beginning Friday (high 80's) so maybe this half day sawing will end.
Bruno of NH
Mr Lynn,
You only have 2 squaring arms ?
Mooseherder
I cut into a Maple Burl today that has been down for 2 years.
I took a 2 inch slab out of it to see what was going on in there.  The blade dove a lil in the center of it I guess because it was harder? There's a Crack that runs thru it but not sure if is all the way thru.  It split in 2 when I off loaded it.  I'm not sure what to do with it yet.
It sits on the mill waiting for me.   :D
Quote from: Mooseherder on September 01, 2021, 05:53:58 PMI'm not sure what to do with it yet. It sits on the mill waiting for me.
Ye ole log whisperer !!   :)
Quote from: Bruno of NH on September 01, 2021, 05:24:41 PMYou only have 2 squaring arms ?
Jim, I suppose that you are referring to the side supports.  I have two powered side supports and two manual.  I very seldom saw short stuff so I have never seen the need to add power to the manual side supports.
Bruno of NH
Quote from: Magicman on September 01, 2021, 06:43:22 PM
I understand
When I ordered my mill Marty powered the center 2 for me.
