Whatcha Sawin' 2022 ??
Started by Magicman, December 31, 2021, 09:58:57 PM
   Probably too long for fire pit benches but a nice thought. I had several yesterday similar to that one that were challenging especially with the size and the curves that would not allow the head to pass and such.
   I opened my e-mail this morning and found a thank you e-mail from my customer which was a classy touch. He had already given me a nice bonus for the work but he knew it was a long, hard day and I still had a long drive home. It is nice to be appreciated once in a while. :D
Sometime with crooked logs, and if the cut list will allow, I will lay the largest and straightest portion on the sawmill bed and saw it as a shorter log.  You will usually still get a few full length boards and the rest will be shorter and the bf yield will usually be more.  I virtually never shorten a log because there is still recoverable "meat" in that top end.  If you buck it off, it's gone.
Old Greenhorn
Quote from: GAB on August 06, 2022, 10:18:07 AM
Dear OG:
Concerning the log in the first picture in reply 1120 you needed to rotate it 90° and saw fire pit benches.
GAB
Benches were not on the cut list and when it's near 100°, I cut what's on the list and get out. :D
 Believe it or not that was the only 'hold' I could get for my opening cut. At 90° for that I had the sweep hitting the head column and at the other rotation I had the burl hitting the column.
 I did the best I could with what I had and where I was.
Gere Flewelling
I have spent the last week finishing up framing lumber for BIL's gambrel roof on new hay barn.  We decided to give cutting out truss components a try on the sawmill.  We used some scrap boards cut to fit over a couple of cross bunks and an 8' backer 2x6 to go against the squaring arms, we were able to fit 26 1''x8 +10" boards in place at a time and saw them all at the same angles.  We cut one side of the peak at a time.  Then we flipped them around to saw the other angle.  I used a log dog to clamp 13 pieces together on each section.  It worked much better than I had anticipated.  Biggest problem was remembering not to raise the saw at the finish of each cut.  Kind of a force of habit when sawing normally.  I am sure others have used this method, but it was a first for me. We got done in about an hour what would have taken days on a table saw and would have been difficult to cut consistently.
Old 🚒 Fireman and Snow Cat Repairman (retired)
Matthew 6:3-4
GAB
Dear GF:
The name of the game on a lot of speciality requests is FIXTURING.
Those that can imagine it, and execute it, will be more successful than those that can't.
Starting with scrap or sacrificial pieces as practice pieces is desirable when dealing with high value material.
I cut some tapered pieces for leveling a floor in a home.  The first 3 or 4 tries went in the scrap pile.
I did get the customer what he wanted.
For your next challenge, if you are daring, try cutting octogan posts for a porch.
GAB
trimguy
What are peoples thoughts on using 1 by boards for truss components, nail boards  ? I have only seen plywood used and I assumed it was because of the different grain orientation.
I would use ply so it does not split under stress, and I always like glue as well.  also I think staples hold better than nails, and less likely to shear than screws.
GAB
Quote from: trimguy on August 09, 2022, 12:12:32 PM
I think it depends on what you are building.
1" would be ok for a dog house, however for a 20' or wider structure I would not recommend it unless you are doing a model.
GAB
I have used OSB for sheds and smaller stuff.
Quote from: trimguy on August 09, 2022, 12:12:32 PMWhat are peoples thoughts on using 1 by boards for truss components
If I did it my choice would be a spiral grain species such as Sweetgum, Elm, etc.
trimguy
Thanks everyone. When this Georgia heat goes away we are going to build a sawmill / air drying shed at my buddies house, it will be 30' wide. I just thought maybe we save a couple of dollars not having to buy plywood.
Resonator
Toured a truss factory years ago, all the trusses were built with steel tie (gang nail) plates, workers had portable hydraulic press to clamp each joint. I've done similar building small trusses (just hammering them on) and they've held up well.
Quote from: trimguy on August 09, 2022, 08:29:58 PM
Don't really see where boards would be a problem, but then we really have not seen how you plan to use them in place of plywood. Not a direct substitute as need to adjust to compensate for the qualities of plywood over boards.
How about filling us in??
trimguy
I was going to use them as nail plates on the joints in the truss. I didn't know how much chance there would be of the grain splitting. 1 by nail plates on full 2 by truss material.
If you have any big subdivisions under construction drive through them and you will find all kinds of osb scraps in the dumpster.  A lot of odd shaped pieces from the roof.  Ask first but they give it away.
Do not cut the plywood to fit on the truss joints, just staple (hold better than nails) and glue down any old way.  Next come back with a router using a pattern bit and trim to the truss.  It's super fast and easy.
fluidpowerpro
Have not sawed for a few weeks and was getting depressed so I decided to saw up 3 gnarly Red Oak logs I've had sitting around. Yes, they do show signs of PPB but sawing them still cheered me up.
Ended up with about 465 bf of 4/4 boards.
Change is hard....
Old Greenhorn
Feels good to hop back on the horse for a bit don't it? I haven't run my own mill since April of '21, too busy making lumber down the road and I surely would like to clean out the logs I had cued up back then. Not to worry about the PPB's, just spray the heck out of them. Good oak is good oak, dry it and make something fun.
fluidpowerpro
Change is hard....
Old Greenhorn
Your logs are too wet for powderpost beetles.  They only infest dry wood.  Your beetles are most likely ambrosia beetles and they cannot live in dry wood so they leave once your boards begin drying. They are not an issue except for the little black lined holes that they leave behind.
However, once your oak boards do get air dried below 20%, they are certainly at risk for powderpost infestation, and spraying with borate now is a good plan if you plan to use the wood for inside use or furniture.
fluidpowerpro
Thanks for the info. The boards have some small holes in them, about the size of a pin head, so I assumed PPB.
Change is hard....
Ambrosia Beetle holes with the black stain is actually a character plus with many woodworkers.  I know that it was with me back when I had a cabinet shop.
Some furniture makers will add some black dots to a finished cabinet, etc. to mimic Ambrosia Beetle holes.
I have seen faux ambrosia beetle holes in furniture too.
fluidpowerpro
This is probably not the right thread to ask this question, but since is about the oak pictured below, I'll ask it here. Last spring someone reached out to me asking if I had any 4/4 red oak boards and what I would charge for it. I gave them a number for wet boards. I won't say what I quoted because quite honestly I didn't have any idea of what to quote, and I still don't...
This person told me he was exploring costs and were in the early stages of setting up a business making some sort of craft item to sell. Forgive me, I forget what it was exactly.
Just out of curiosity, I reached out to them today asking how their venture was coming along. He responded and said that they have started mfg but are not up to full speed yet. I asked if he was still interested in wood from me and he responded that they are buying 4/4 ro boards, kiln dried, and planing down to 15/16. They want select grade, at least 5" wide. All of what I have is wider than 5" so that's no big deal but I need to learn about grading because I don't know what I have.
I did look into the cost to have kiln dried and was quoted $200/1000 bf, 500 bf min, plus .10. / Bf stickering charge, so basically .30/bf total. I have never had anything kd before. Does that cost seem reasonable? I would have to drive about 75 miles each way to drop off and pick up, so that will be some cost I need to account for also.
In summary,
1. Is that cost for drying fair?
2. How much can I reasonably charge for this wood?
I would quote it delivered assuming I can drop it off on my way back from picking up at the kiln.
Any guidance would be greatly appreciated.
Change is hard....
DWyatt
I'm not sure I would put wood in my kiln for that. It seems cheap, especially for oak.
