I love this Track Saw!
Started by Brad_bb, November 09, 2019, 10:59:27 PM
reedco and 4 Guests are viewing this topic.
Crusarius
I am using the powertec track, which supposedly is compatible with makita as well.
Interesting idea on the notch, I bet you could make it work with some creative jigs. something as simple as a v notch board that screws onto the track or clamps into the groove.
I have been very happy with the saw and track setup I use it quite a bit for edge straightening. What I did find out though, if the board is twisted unless you suspend the track the edge will not always be 90 degrees.
xlogger
I'm about to pull the plug on a Makita 9 1/4 cordless track saw. Don't really need cordless. Saw sold separate with out rail or battery. I'm using it mostly to rip live edge slabs from 4-12ft long. Longest rail showing is 118" or short one at 55". Is there any other tracks that will work? Also has anyone here have this saw or know about it?  Found at 2 sites, Toolnut and a little cheaper at Toolorbit.
Brad_bb
Quote from: xlogger on December 19, 2022, 03:47:38 PM
I got it for cutting slabs, I got the deeper cut Festool, TS75.  I didn't even consider cordless because one, cordless isn't going to cut that deep, but two, because I don't want to be amidst a cut on a slab and have the saw stop/run out of juice.  You'd likely have to start a new cut then as stopping might cause a blip in your rip.  I don't want to take that chance. Corded = more power and non stop.
Old Greenhorn
Man, I HATE it when I get a blip in my rip! :D
xlogger
Walnut Beast
Yes.   Get efficient cutting without the cord with the XSH10Z. It makes up to 110 cross cuts in 3x12 oak board using two fully-charged 5.0Ah batteries. The electronically-controlled brushless motor delivers a full 4,500 RPM for efficient cutting, with Automatic Speed Change™ technology to adjust the cutting speed and torque under load for optimum performance.
xlogger
looking for mainly other track that will work, different lengths
Crusarius
With my track saw I find that the track is either just to short or way to long. I have 2-55" pieces. Be really nice to have one a little longer and one a little shorter.
Quote from: Walnut Beast on December 20, 2022, 06:25:27 AM
WB
You have this one?
How long have you had it?
A review?
21incher
With no plunge feature your going to need an extra 2 feet of track for a straight cut. I have all 3 sizes of the Makita tracks and they are all glue line straight even when joined. I use the long rail the most. Don't skimp on rails. The truck freight on the long rail can be pricey due to the crate length.
Dave Shepard
Festool and Makita track are supposed to be compatible. Milwaukee's new track saw its supposed to be, as well. My TS75 is one of the few corded tools I have left. I would go cordless, if it was an option.
xlogger
Quote from: 21incher on December 20, 2022, 12:22:21 PM
Thanks for reminding me about plunge feature, I over look that. I wish Festool where available.
One I was referring to above. Price there doesn't include batteries and charger.
Buy Makita 40v Circular Saw Xgt W/55in. Rail at Busy Bee Tools
alan gage
I have 3 different lengths of makita track and connect them as needed.  No problems.
I use them with my festool saw with no issues. They were considerably less than festool track and, if I remember, slightly longer.
Alan
Walnut Beast
Quote from: beenthere on December 20, 2022, 11:25:02 AM
WB
You have this one?
A review?
No I've got a Festool TS75. But when  the dealer Toolnut was out of the 75 they recommended that unit as a replacement on their website. I've thought about getting that unit for extra cut capacity and portability. If I get it I will definitely give it  a review. The online reviews were really good and they said it was better than the newer 40v single battery. The two batteries had a faster rpm better cutting. And the run time was about the same
xlogger
on the makita batteries does the cheaper batteries hold up well
Actually the 40V has better sustained power even though less RPM's and the battery comes with 2.5 ampH, but a 5 ampH is an option. It actually cuts faster in the end. Those two batteries on the 36V overhang a lot, interfering with some cuts, making it wider and heavier and the top 18V battery is a bit of a knuckle banger. :D
Makita 40v Plunge Saw Review | Is it Better than the Makita 18v x2 Makita Track Saw - YouTube
xlogger
Quote from: YellowHammer on January 06, 2020, 09:54:03 AM
I never use the stock blade, it's good for crosscut but not for ripping.  I use the 16 tooth Panther ripping blade with much better 2" deep rips and easily resharpend.  It will crosscut slabs fine, also.  I've also used a couple other ripping blades, but keep going back to the Panther.
I also keep a couple screwdrivers stuck into the foam board.  Whenever the wood starts to bind the saw, I'll jam a screwdriver in the kerf to jack it open.  That's works really well.
wonder if the panther ripping blade will work on the Makita 9 1/4", have not found a ripping blade for it
xlogger
Quote from: SwampDonkey on December 23, 2022, 04:35:47 AM
Do you have a ripping blade for your tracksaw, I can't find one for the 9 1/4" blade
xlogger
Just got off phone with tool hut makita only offers in the 9 1/4" blade a 24 tooth, do you think that will do a good job ripping slabs
xlogger
Quote from: Walnut Beast on April 17, 2022, 07:44:46 AM
Festool is great but no 75s now. And been that way for a long time. Toolnut
Recommends this unit in place of the 75 and it's cordless and cuts over three inches and will work with the Festool track.
The XSH10Z is compatible with Makita Guide Rails (sold separately) for accurate ripping. With a large cutting capacity of 3-3/8" at 90◦, the XSH10Z can conquer demanding applications such as ripping and cross cutting larger beams, boards and forms.
I got this saw a few weeks ago with 3 different tracks, I've use it a little now. On ripping longer slabs one did well and another got stuck . I keep wooden wedges near and stuck one behind saw but didn't free it very good. Not being a plunge saw what should be best to do?
teakwood
Just read this whole topic. More and more people want me to cut the glued up panel i sell them to length. A friend will lend me his festtool tracksaw 55 so i can finish a order, will see how that works out.
Watched a lot of videos about makita vs festtool. all my battery tools are Makita so i'm very inclined to go with the same brand, get a second charger and more batteries. i have makita batteries that are 8 years old and still go strong.
Very important will be the square cut gismo, so i can speed up the process. what do you guys use to square and parallel?
Dakota
I have the corded Makita track saw.  My only gripe is that it will only cut a 2" slab.
Dave Rinker
trimguy
I have the corded makita also and like it.
