Tigercat to discontinue 2 skidders
Started by timbco68, April 19, 2023, 07:55:34 PM
BargeMonkey
I just come here to watch you guys work for a living 😆. No the one I'm getting is technically used, someone bought it and realized after 3 trips it wasn't what they wanted.
Anything that has the capacity to gross over 990 in NY, and then if it's able to gross over 9900 you fall into the next category.
Ramon I will get a copy of the brochure, and what options / sizes and send it to you. Roughly 6k and up, how fancy you wanna get.
 I spent the morning researching and stressing over buying a new $13K dump trailer, Barge would buy two or three of them while on lunch break without batting an eye😁
Southside
I think that's a FED DOT rule Barge because here you don't want to be going down the road with a 1,000 gallon tank that has a drop of fuel at the bottom without all the Haz Mat permits.
Walnut Beast
Quote from: BargeMonkey on May 03, 2023, 10:15:19 AM
You said it how fancy do you want to get some of the ones the farmers have at 45k +
Skeans1
Quote from: Southside on May 03, 2023, 02:02:11 PM
Dot requires placards after 119 and an endorsement.
BargeMonkey
 The DOT cop got talking at the last class, everyone got asking questions and transfer tanks came up, if you had an empty 275 in a truck that wasn't stickered they would get you, same as carrying the saw on a loader trailer, another possible ticket, like anything it depends on the creeper clown and if your on the radar.  New with the fancy pump and paint they are 8200 for a 750. Pay taxes and support the drug addicts or go buy something.
Log-it-up
I thought federal law was capped at 99 gallons after that you needed hazmat license and placards
Log-it-up
And creeper clowns 😂 that's a good one I thinks that's going in the vocabulary bank
Firewoodjoe
Some of the guys here have a tank right on the landing. The fuel company will delivery a tank and keep it full. We lock everything and put cameras up anyways.
