Off road diesel
Started by nativewolf, May 24, 2023, 07:17:56 PM
BAN
Quote from: quilbilly on May 26, 2023, 11:11:02 AM
@BAN are you getting ready for fire season? That quick warm up a few weeks ago made the snow over here on the wet side disappear fast
Yes we are. We had a very cold spring but not unusually wet so this could be a bad fire season. They are predicting a late hot summer so we shall see.
Hogdaddy
3.00 a gallon is what I give for the last I ordered. AW46 hydraulic oil was way cheaper by the barrel for me, I saved over $5 a gallon, and I it was better oil
If you gonna be a bear, be a Grizzly!
Firewoodjoe
What's the hydro oil prices? My last pallet was $35 a pail. The cheap stuff. Meets all major specs it says 🤷‍♂️
Firewoodjoe
I've been thinking about buying the drums from my fuel supplier. Name brand and they deliver. I don't know pails are nice.
nativewolf
I like southsides idea of buying a pallet of buckets.  Get a per gallon discount but still in a bucket.  I have a couple of leaks on my forwarder grapple at the moment.  2 lines, the rotator, and a cylinder.  The lines will get changed in 2 weeks when we can shut down for a day and do some deep maint.  The cylinder can get repacked that day too.  The rotator...that's maybe going to drip oil.  I am pretty sure I don't want to do that repair and am thinking about the best way to get it done (do a long shutdown and just send it out is my favorite option).
Anyway, I have always used a bit of aw46 and I expect that continues.
Liking Walnut
 NW, sometimes the rotators will leak from a little plug in the side. Iirc it is a 10mm Allen head, and it has an o-ring that can go bad, causing it to seep.
Skeans1
Quote from: barbender on May 29, 2023, 01:47:58 PM
When doing that double check that the rotator shaft is sitting square in the bore of the base. If not loosen all mounting bolts as well as the two side clinch bolts and tighten the wedge in with the grapple square on the ground.
Skeans1
Quote from: nativewolf on May 29, 2023, 01:29:48 PM
Rebuilding the rotators isn't that bad of a job it just takes a little bit of time and patience. As far as oil goes I can get a 55 drum cheaper then a 55 in pails most of the time and we use the race gas cans to haul the oil in it's much easier to deal with then 5 gallon pails with the shape being square and the top is larger.
OH logger
Quote from: Firewoodjoe on May 28, 2023, 10:34:55 PM
JD hygard is about $100/5 gallon I think. My skidder hyd system uses JD hydrau XR. If I recall it's about $200/5 gallon pail 😮
john
Firewoodjoe
Yeah that's what I do. But it's not good oil. Cheap off brand stuff. Wood's equipment usually is fine. Because blown hoses and such. Oil is usually very new.  Just don't use it in a clutch application.
BargeMonkey
There is a glut of oil right now. The economy is slowing down, I'm watching oil barges get stacked due to lack of work.
My price thru the holiday. Almost .20 between 87 gas and onroad, it's all a racket.
Firewoodjoe
I guess. Take the good with the bad this year.
B.C.C. Lapp
Just bought off road diesel this morning.   $3.11 a gal.   I'd like to see it back down under $3 but that aint gonna happen.
Listen, or your tongue will make you deaf.
Firewoodjoe
Mine was 2.60 Friday.
chevytaHOE5674
Paid $2.90 for 1400 gallons a week or so back. Knowing my luck its a good bit cheaper now....lol
Firewoodjoe
Yeah mine was bouncing around 2.90 for a long time. This was the first below 2.88.
