The Daily Firewood Picture Thread
Started by mike_belben, May 09, 2021, 11:23:57 PM
If you are on a Windows machine.
Shift Option 8 always added the degree symbol on my MAC, ° OK, it still does.  I think that I was not holding both the shift and option down simultaneously before the 8.  °°°  Got it now.
OK, option and the numeral 0 also produces a slightly larger º
°°°   ººº  yup larger.
° <- Alt+0176 on Windows. It doesn't appear until you release the Alt key, and you have to use the numeric pad numbers.
Beenthere's keystrokes work also, but I got the key code from the Windows character map.
g_man
I just use shift asterick: like -25*F
gg
upnut
Old tree cleanup continues...
Processing limbwood is going well, the big chunks will require reinforcements.
Scott B.
I did not fall, there was a GRAVITY SURGE!
Is it just me, or is the photography better quality?
Some of the pics are not being put in their gallery, appears to me.
Quote from: beenthere on February 02, 2024, 06:35:49 PMSome of the pics are not being put in their gallery, appears to me.
You now have the option of posting directly to the post. It wont be in a gallery, only where it was posted. You can use either or. Easy-peasy
Also, the new gallery embed code takes you directly to the picture in the gallery when you click on them in the post
Tonights clover cam pic
g_man
Quote from: Jeff on February 02, 2024, 06:43:12 PMAlso, the new gallery embed code takes you directly to the picture in the gallery when you click on them in the post
I couldn't figure out how to get a pic from my gallery into a post. Any hints ??
I also thought quality was better.
gg
Copy the embed code in the i fo box inder the photo and paste it in your post. That easy.
g_man
Quote from: Jeff on February 02, 2024, 07:36:44 PMCopy the embed code in the i fo box inder the photo and paste it in your post. That easy.
Thank you much. Your right - too easy. I won't ask what embedded code is. Sounded scary to me.
gg
Quote from: g_man on February 02, 2024, 07:55:32 PM
gg
Its the stuff that makes your picture appear in the post
GRANITEstateMP
Firewood pile is in hibernation for a little while longer
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
How do you get to your gallery and back to the post.  it is taking about 10 clicks for me, and only one pic at a time.  copy and paste.  seems the same to get to the gallery and then past the URL.  can I go straight to my gallery from here?  the click or drag is looking on my computer.
can you press control and do several at a time?
I might need a video, Jeff.  😲  at least I figured out the emoji stuff.  😏😂
Doc, I am opening two tabs, one with the posting window and the other with my open gallery.  It's a simple matter to click and switch back and forth between them.
thanks so open the second in "a new tab"?
Yes I open a new tab, log onto the FF and go to my gallery in it.  That way I have my gallery open in one tab and the posting window in the other.  I then click from one to the other.  Copy my picture address in one and paste it in the other.
You are pretty smart (not necessarily pretty) for an old guy Lynn! smiley_old_guy :) :)
are you able to drag or do you copy and paste?
got it.  drag I did not get.  this is in Oklahoma at the mercantile with the pioneer woman Rae Drummond.
I copied and pasted.  I do not know how to drag from one tab to another and I think that I would need two screens to drag and drop.
I'll give drag and drop a go here, gallery in second window.
One of those is the code dragged over the next was drag and drop on the bar below the post window.
