More sharpening advice
Started by AaronS, February 01, 2024, 08:00:33 PM
 I'm with ST, I think you have it adjusted wrong and the stone is coming right down on top of the tooth. You don't want to way over tension the holder either, you'll fry your gearmotor smiley_thumbsdown
In the top notch drawing above, the tooth to the left is where the wheel should come down. The one in the center is how I think your wheel is coming down on top of the tooth.
SawyerTed
@barbender has captured it with his "top notch" illustration!  It's actually worth 1,000 words.
Here is the link to the BMS25 sharpener manual.
https://apps.woodmizer.com/Manuals/EngDoc.aspx?man=sharpener%2fpdf%2f2448.pdf#page19
Section 4.4 describes the adjustment for face grind of the tooth.
AaronS
Brad, that's considered a large radius? And I thought I was keeping it fairly small...
If that's true then, I guess I should be keeping the radius almost 90 degrees?
Want some good news? https://youtu.be/YfIvK1IeyAI
AaronS
Barbender and ST, I could be wrong, but I've been trying very hard to take just the tiniest amount off the face, knowing that too much would cause a negative hook angle. There is an adjustment for the push rod, yes. I've used it quite a bit playing around! Could you weigh in on the wheel profile? Is the radius too much like Brad was saying?
Bradm
I run an almost square corner on the grinding wheel and adjust the angle on the OD if needed.  I also lightly dress the profile with a Desmond dresser every band/pass.  I never dress the inside face as doing this will add that taper to the wheel.
Barbender's drawing shows it quite well on the left.  Even though there is a fairly large angle on the OD, the left hand side of the grinding wheel is parallel to the tooth face while in your picture the deep profile shows what I'm talking about at the bottom of the tooth to where it transitions into the gullet.
AaronS
Wow, well then maybe that explains it... thanks for pointing this out Brad! I'm going to reprofile the wheel to square up that inner radius and take another shot at it.
SawyerTed
If the stone matches the profile of a new blade then the stone profile is correct.  Otherwise, the stone needs to match the new blade profile.
Bradm
Before changing the profile of the wheel, compare the profile you are getting when sharpening with a new, never been sharpened band (flat pack them and line up the tooth faces).
RAYAR
Quote from: AaronS on February 14, 2024, 02:31:10 PMI noticed a tiny bit of sway side-to-side of the whole grinding wheel assembly, but I can't get the hinge any tighter... could that be it?
Sounds like you likely found the root of the problem. This has to be taken care of, there should be no side to side movement as that will cause the problems you are experiencing. Cutting down on a piece of tin, the full face of the wheel is grinding, but on the blade, you're just catching the left edge of the grinding wheel and it's being deflected to the right as it grinds down the face of the tooth.
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
ladylake
 One other thing to check, in some of your pics it looks like the tip of the tooth is flattened out right at the tip like the sone isn't. lifting high enough. I had that happen once when a spring on my grinder go weak not lifting  the stone high enough flattening out the tip of the tooth.  Even with power feed the mill wouldn't feed. Put a stronger spring in my grinder and it fed good again
Joe Hillmann
In a previous post you said you were setting a 19-21 thousandths.  I find when cutting pine that isn't enough.  I aim for 15-27 thousandths.
And since I dislike setting blades I will often push it all the way out to .030 of set so I can get 2 or 3 very light touch up sharpening out of it before I have to set again.
Although when the logs are frozen .030 leaves too much sawdust behind that causes the board to freeze back to the can't once the blade passes through.
