Whats Fuel Prices In Your Area?
Started by GF, July 08, 2005, 08:30:01 AM
21incher
Al_Smith
Propane ,Ottawa Ohio $1.69 on a leased  tank with a nickel off if the bill is paid in ten days . $1.59 on an owned tank .  I went through about 400 gallon last year ,wood burner ya know . 8)
GRANITEstateMP
Just paid $2.89 a gallon propane to top the house tank off (stove, hot water, and if heat kicks on cause I didn't fill the stove). $3.09 for 87 at the fuel pump yesterday near Concord, NH
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Ljohnsaw
$4.09 for regular but if you go to depressed neighborhoods, as low as $3.89. Propane swap tanks $25!!!
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
moodnacreek
Gas as low as $2.96 but going up. Red fuel about the same.
Chuck White
For a while, 87 octane was $3.39, but about a week ago it went back up to $3.49!
I just don't understand why there is so much diversity in the prices around the states, but I lay it mostly to the cost of delivery!
Funny, when the news says the price may go up here, it goes up almost overnight, but when it says the price will be dropping, it takes quite a while for it to be noticeable here at the pump.  :huh?
lurk
You guys have got it good over there.  It's about £1.51 per Litre here in the UK. Costs me an arm and leg to fill my car.  ffsmiley
TGMForum The Garden Machinery Forum
TGMForum Youtube Channel Please subscribe
tino
Quote from: lurk on February 18, 2024, 10:19:58 AMYou guys have got it good over there.  It's about £1.51 per Litre here in the UK. Costs me an arm and leg to fill my car.  ffsmiley
I assume you mean Diesel? It's £1.39 p/L for Unleaded down here on the South Coast.
Ljohnsaw
Last fall, prices were to drop because of switching to winter blend (less additives) but would be offset by lower production because of plant shutdowns for yearly maintenance.
Now they are getting ready to switch back to summer blend in 2 weeks. Prices are already climbing because of yearly maintenance starting...
smiley_thumbsdown
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
lurk
Quote from: tino on February 18, 2024, 11:06:10 AM
Yes, sorry tino it was for Diesel. Mind you, not a lot different for Petrol here in Essex.  I will check tomorrow.
customsawyer
If my math is right, that makes it close to $8.00/gallon? Give or take a bit
www.thecustomsawyer.com
OlJarhead
That's $1.91/liter which translates to $7.16/US Gallon (3.75l to the US gallon vs. 4l to the imperial gallon).
Yikes, that's terrible!  Here where we pay more than most, it's around $3.59/US Gallon for unleaded.  Diesel is still running over $4/gal
