Training the Friars story 5-10-2024
Started by Jim_Rogers, May 10, 2024, 07:12:11 PM
Jim_Rogers
A while ago, I sold a set of plans for a 16x20' cabin to an order of Franciscans Friars.
They are in a small town in the foothills of western North Carolina.
They own 70 acres and are harvesting their own trees (yellow poplar) to be milled with their own sawmill.
And were ready to have some face-to-face hands-on instruction.
So, Dan Flinn and I went to their work site and taught 14 of them for a week.
In between daily prayers, they managed to get a lot of joints cut. And most if not all were good woodworkers.
On the last day, I taught them how to "test fit" all the joints in a bent so that they could see how it all goes together.
See attached photo of them doing a "test lift" to see how heavy a 16' wide bent is.
We'll be back there again some time to help them raise the frame.
Jim Rogers
mattlynch
dearchap
Jim do you have a photo of the completed shed ?
Jim_Rogers
Quote from: dearchap on July 26, 2024, 09:37:48 AMJim do you have a photo of the completed shed ?
dearchap it is not a shed it is a cabin.
And here is the latest photo I have received from them:
Jim Rogers
Ljohnsaw
Looks a bit drafty. Is it a corn crib or will it be plastered or mudded?
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Jim_Rogers
The infill of the wall system is called Wattle and Daub. The photo shows the wattle installed. The duab is dirt/mud/clay/straw mixture that will be hand pressed into the wattle. And then it will be covered with a lime plaster.
The plaster will be on both inside and out.
Jim Rogers
Ljohnsaw
I couldn't think of what it was called. Cool.
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
