Something is eating holes in one of my maples
Started by 21incher, August 23, 2024, 06:06:32 PM
21incher
Just noticed one of my maples had started dropping leaves on one side early.  Found a bunch of small holes eaten in the bark on that side. Here's a picture.  Looks like bug holes that are slightly tapered. Wondering if I should try spraying the holes with pesticide.All on the NE side that's shaded.
rusticretreater
probably bark beetles.  Spray or inject pesticides asap.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Insects would be secondary to a greater problem already started. Those holes look more like sapsucker to me. Did you do any earth work around the roots? Maple is sensitive to having top soil laid on top of the ground, smothers the roots.
21incher
Quote from: SwampDonkey on August 23, 2024, 08:12:06 PMInsects would be secondary to a greater problem already started. Those holes look more like sapsucker to me. Did you do any earth work around the roots? Maple is sensitive to having top soil laid on top of the ground, smothers the roots.
I looked up sapsucker damage and that's exactly what the holes look like. I haven't  done dirt work but back in 1990 they bulldozed that area to level it out some when they prepped the land for our house.  It's  a big beautiful tree that ys off and only on that one side. So sounds like not much can be done. Thanks
YellowHammer
That's what came to mind to me, a hardheaded woodpecker getting a good meal out of your tree.
Since the holes are arranged in the pattern of an arc, it means the woodpecker stayed in the same spot and just moved his head over to pop the next hole to find the grub.  Whenever the arc of the hole pattern changes shape, he moved over and got a new foothold.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Old Greenhorn
Definitely Sapsucker holes, not woodpecker.  Woodpeckers will rip holes trying to uncover food. Sapsuckers just want the sap.
 Not to worry, they will heal over. I have a white oak here with the same exact thing. I doubt they are connected to your leaf die off, but if they are it should only be temporary.
 This too shall pass.
Sap attracts bugs, they eat the bugs on the sap holes as well as lick sap. Secondary opportunists are the hummingbirds up this way that come along and lick the sap. I've seen severe peck in some trees causing death. They keep coming back to enlarge the old holes, eventually girdling the tree.
YellowHammer
Quote from: Old Greenhorn on August 24, 2024, 10:17:42 AMDefinitely Sapsucker holes, not woodpecker.
I didn't know there was a difference.  I figured a sapsucker was just a woodpecker with a straw in its beak.
YellowHammerisms:
21incher
Quote from: Old Greenhorn on August 24, 2024, 10:17:42 AMDefinitely Sapsucker holes, not woodpecker.  Woodpeckers will rip holes trying to uncover food. Sapsuckers just want the sap.
The leaf die off is just on the side above  the holes. Guess  I can put the chainsaw away, wait and see what happens  next. I'll have to put a camera out there to see if it returns.
Thanks everyone.
