Chain lube inside of edger
Started by DocGP, September 11, 2024, 10:48:30 AM
DocGP
What are the thoughts on the best chain lube for inside the edger??
Would atf be as good as anything, or would a dry lube chain spray be better?
Thoughts appreciated.
Doc
Ole Country Vet
LT 50 HDD
MX 5100 for the grunt work
Stihl MS 261 C-M
customsawyer
I just use ATF on my edger chains and the shafts that all of the collars slide on.
www.thecustomsawyer.com
240b
ive been using bar/ chain oil
on shafts an chains
seems to work
customsawyer
Any lube will help. I use the ATF as it is thinner and all of the sawdust doesn't stick to it, like it would with a thicker oil. I buy whatever is cheapest in 5 gal. buckets and put it in a pump up sprayer.
YellowHammer
I've been using cotton picker spindle oil
Really
I've got buckets of it
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
