Felling wedges
Started by DanL, November 05, 2024, 10:09:39 AM
DanL
I am in need of a few felling or bucking wedges. I make my own from local Ironwood ( Hornbeam or Hop Hornbeam). However, I like to keep a few plastic/synthetic ones around.
Considering hammer impact durability and other, do y'all have any particular favorite brands and/or sizes?
From God's Farm in Alabama
"God bless America" and "Alba gu brath"
I like the idea of making some.  I buy some Stihl, and others no name brand, like 15 in a bag, for the sawmill to back out a blade.  We do not have a big logging industry here, so the name brands are limited.  most of my falling does not require a wedge.
RetiredTech
I have a bag of assorted length no name plastic wedges that I use mostly to keep from pinching my saw blade in a downed tree. I don't cut many trees down that are standing straight up. Most of our firewood and my sawmill wood is blown down already or hung up in another tree. I do have a few metal wedges, but hardly ever use them anymore. If I needed to cut a big tree, I'd use the metal ones.
Philippians 4:8
Branson 4520R, EA Wicked Root Grapple, Dirt Dog Pallet Forks, Woodland Mills CM68 Chipper
Echo cs-450 & cs-620p , Husqvarna 136, Poulan Pro, and Black Max Chainsaws
Partially built bandsaw mill
Grandpa
I like K&H wedges.
Jim Chance
 I always wanted a "second wedge" for when you need more lift than one wedge. The thin end would be a bit thinner than the fat end of a regular wedge, the fat end twice as thick. I think it would be better than stacking wedges.
I have a pair of wedges that are grooved so that you can stack them without them slipping apart.  Like triangular T&G that mesh together.
gspren
I'm not necessarily recommending this for a few reasons but I've used splitting wedges for some extra lift or when trying to recover a pinched bar.
Stephen1
Quote from: doc henderson on November 05, 2024, 02:05:10 PMI like the idea of making some.  I buy some Stihl, and others no name brand, like 15 in a bag, for the sawmill to back out a blade.  We do not have a big logging industry here, so the name brands are limited.  most of my falling does not require a wedge.
Doc, If I have to back out a blade, its because I hit hardware and the blade is toast,  Terrific Timber showed me how to use my grinder with a cutoff wheel to cut the blade on both sides of the log,   saves so much time and  effort!
I practice directional felling on every tree I cut. With that in mind probably 80% meet a wedge or two. I only buy 12" long wedges as shorter ones don't give me as much lift and are harder to drive (I'm lazy). I looked to see what brands I have and found a big variety so I guess no favorites. I drive the wedges with a short handle sledge, boy's ax, or a home made wood mallet. Since I don't have to pound as hard, I seldom destroy wedges putting them in.
With directional felling I bore cut exclusively. Cutting a wedge with the saw is common for me, operator error I suppose.
I sometimes will use a wedge to back out a blade but most often I cut it as suggested earlier. If I do back out a blade, I have a 3' section of a old blade that I put a wood handle on. Teeth face me. I use this like a hand saw to clear the kerf of sawdust before backing out the band. Helps a lot.
Most times I put a wedge in, Sometimes I need to pound it in, other times I don't touch the wedge.
John Mc
Quote from: Jim Chance on July 05, 2025, 07:10:20 PMI always wanted a "second wedge" for when you need more lift than one wedge. The thin end would be a bit thinner than the fat end of a regular wedge, the fat end twice as thick. I think it would be better than stacking wedges.
What I do in the case where one wedge doesn't provide enough lift to tip the tree: cut a cookie slightly thinner than the thick end of the wedge. Drive the first wedge. In the gap that creates, slip in the cookie, then pound my second wedge in on top of the cookie. (If that doesn't tip the tree, the first wedge is now loose. Pull that out, slip in a thicker cookie that takes up most of the current gap and pound the first wedge in on top of that.)
I really don't like stacking wedges on top of each other. Too often, when I'm driving one in, it wants to spit the other one out. This doesn't seem to happen with a wedge driven on top of a cookie.
