Shade tree mechanic! Whatcha workin on.
Started by doc henderson, June 23, 2024, 10:24:13 PM
NewYankeeSawmill
Welp, we've been upgraded to a blown head gasket!
Replacing the injectors and re-setting the computer seemed to have a big impact (as did Mobil1 Fuel)... then I started getting a cooling system leak. Replaced the water pump, a hose, still squirting.
Sigh. That's miles above my pay grade. Thankfully a friend has offered to help. I just have to cough up for the parts and the beer. Works for me!
Norwood LUMBERPRO HD36V2
Stephen1
A friend and utube will fix that pretty quick. I blew a head gasket on my 93 bobcat years ago, that was above my pay grade also, needed a rad and the head had to be machined, actually they baked it in an oven for24 hrs as it had warped, straightened it and machined it. I was able to get it back installed and running with the help of tube. The machine shop laughed at me when they gave it backed to me and everything was in a box. I had given it to them all tagged and marked so I could just put it back on.......It went back together pretty easy.
Machinebuilder
my current miserable mechanical job
That's the leaking hose going to the left lift cylinder. there is no way to get wrenchs on the hose to tube fittings in the machine.
I am still struggling to get the 2nd hose out, I only have about 3 1/2 hours in this job so far.
I hate working on Bobcat. there is so much in such a small space that is difficult to get to. it just started leaking too much to just keep adding oil.
I had a kinda similar situation once and went back totally flexible.
Big_eddy
Quote from: Machinebuilder on November 12, 2024, 07:34:26 AMmy current miserable mechanical job
Looks awfully similar to the job I just did replacing the leaking transmission oil cooler lines on my F150. After messing around for way too long with flare nut wrenches, I buzzed the rusty old lines off with a zip wheel and put a socket on the fitting. If I'd thought of it earlier, would have saved an hour of cussing.
rusticretreater
Sometimes you gotta make the tool you need.  Weld it, bend it, grind it. Sometimes you need to remove other parts to get a good angle on it. Whatever it takes. super-smiley
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Resonator
I put a new starter in "Old Rusty" the other day, my '07 Ram 2500, and it actually went pretty good. Used a 4x8 sheet of plywood to lay on, and drove the front wheels up on boards to give me a little more room underneath. The starter in there technically still worked, but to get motorvated need a little tappy - tap with a hammer. ffcheesy
Best part was since I had replaced this same starter a few years ago, the parts store covered the full cost under the warranty. ffcool
Locally, we could always get them rebuilt. Wasn't all that expensive back in the day.
should get my relined brake shoes back today.  now it will be cold! :dry:
Old saw fixer
When I worked at the local Chrysler Dodge Plymouth dealer('68 to '78) as a mechanic, the parts department stocked OEM new parts to rebuild starters, alternators, steering pumps, and more.
Those were the good old days!
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M, NG 7 Chain breaker/spinner
Echo CS-2511T, CS-3510
Logrite Cant Hook (with log stand), and Hookaroon
This place relines brake shoes and can find old truck parts.  buck is the guy in charge.  they are 40 minutes away and they have a route to pick up and drop off.  they also give away calendars with pictures that could make any man or woman blush.  They apparently have a version for both genders and occasionally as a joke will give a truck driver the wrong one.  Old fashioned fun.
Resonator
QuoteLocally, we could always get them rebuilt.
I know guys with all the tools and heated garage space that would rebuild them themselves, I tip my hat to them. :thumbsup:
Laying on the ground in the cold, needing to get the thing fixed and running, I just bolt on a new one. ffcheesy
these shoes are no longer available.  He had trouble getting cores and I told him, he can use mine. ffsmiley
Often it would be a tractor, or potato truck needed to farm. There was a day when stuff like that was fixed and you walked back out with it or the next morning picked it up. Same with saws, most of these John Deere dealers who carry Stihl saws, stock no parts at all these days. I could go to Harold a few years ago at his shop and I walked out with a fixed saw or he loaned me one until mine was fixed in a day or so. Don't expect it now.  ffcheesy ffcheesy
Sylven passed away, but he was the saw guy at the Amish dealer.  He would wonder if he had it (a part you needed), but almost always did.  One time I was out sawing and had my gooseneck and skid steer with me.  saw kept dying and then would run if I filled it with fuel.  he told me it was prob a crack in the preformed bend in the fuel line, but he went to lunch at 1:30.  Lunch for him was a packed lunch box and he sat on an old car bench seat in the lobby/front of the business.  Had to unhook the trailer as it was half full of unsecured wood.  wanted to finish, so I did not have to come back.  I got there and expected he could not finish it as it was 1:15. He tried to act grumpy but was OK if he felt you appreciated what he did.  He worked on it using a tool he made to pull in a new fuel line.  It had also broken the drive sprocket, and he replaced it and put it all back together.  took it out to check it with a tach and tuned it up.  He said, it is not throwing oil.  took it back in and took it all back apart to find a part plastic worm gear that pumped oil, packed with saw chips and oil and broken.  He found one on the shelf and fixed it.  still confirmed it was throwing oil.  I apologized for him missing lunch.  He said, no matter, I will go sit and eat for a half hour, no matter when it starts.  Old school.
Nebraska
Wish there were more like him.
Well, spent a bit of time on the sawmill before it decides to get too cold.  Was cutting pine and noticed a delay in the blade clutch engaging.  It finally would not engage the blade for the final cut.  Matt at Timberking @Will_Johnson  thought it was likely the air gap on the clutch.  I took off the cover/guard and was happy to see, I did not have anything else to remove.
You can see the oil-soaked saw dust, from a slow (for now) seal on the output shaft.  Project for another day.  Hoping it can be changed without major teardown.
I watched a few YouTube videos.  the slots around the clutch housing are access for a feeler gage.  I need it set to 0.018 and was able to work a feeler gage into the three slots and snug the three spring loaded nuts to meet spec.  I also checked wiring and found one connection that came apart a little too easy.
three slots like the one at the top of the photo.
It is a bit tight.
Update:  I have nearly all the parts to put the ol dump truck back together.  Need the flex hoses and a few springs and clips, and one mor 5/8th inch wheel studs with left hand threads.  My brother had surgery for carpal tunnel and a cubital tunnel release.  She is up securely on jack stands on plywood bases.
Machinebuilder
Well after much fighting and lots of words I finally got the lines back together on the Bobcat.
I haven't even found any leaks yet............I hope I didn't curse myself.
No I am at a point where It drives fwd/rev, but doesn't lift or tilt.
I did find a few broken wires and i had broken one valve coil. I think that is all correct.
The coil should be the interlock system valve, I am thinking i may have bent the valve when I broke the coil.
I just ordered a new Valve and should have it in a couple days.
Of course it is at the bottom of the valve block and will be a joy to get to.
It's supposed to be rainy so I am back to inside projects again.
Peter Drouin
Hot Rod on the lift heats on rock and roll is in the air. New suspension parts going on. ffcool
aigheadish
Machinebuilder- Nothing sounds fun about that.
Machinebuilder
That would be an understatement.
I ended up with quite a few connections undone. I found many of them unbelievably tight, to the point of distorted threads.
JIC fittings (37 degree flare) do not have to be extremely tight. A -4 (1/4") is 1 1/12 flats past finger tight, a -12 (3/4") is about 1 flat.
I spent quite a bit of time with a thread file fixing one adapter.
Machinebuilder
IT"S ALIVE.
I installed the new valve today and everything works.
I used it for a good while and don't see oil dripping anywhere so the leaks are fixed..................for now.
I wish newer machines were more affordable,I get tired of fixing this old stuff.
TimW
My CAT E70 excavator started out life as a Mitsubishi MS070. CAT rebadged in when they bought out Mitsubishi.
After 25 years, my exhaust pipe elbow cracked.  To add insult to injury, I cut the wrong elbow off.  So I had to replace two elbows.  Amazon Prime excelled in this endeavor, as I had everything I needed next day.  But had to buy two exhaust u bolt clamps from O'reilly auto supply.  As The elbows are a little higher than factory.  I threw some witness clay on the ubolt to see if the hood cleared.  Got 1/4 inch gap.
TimW
As usual, it is always something that breaks and needs fixing.  Now it is the Gully culvert.  Double wall corrugated black plastic, 4 foot in diameter.  It got a split in it.
Had this metal on hand and had it bent into a 2 foot radius.  But it looks like it is rolled.  Rolled .vs Bent is 3 times more $.  It gets installed tomorrow.
