What are you cutting 2025?
Started by Ianab, January 04, 2025, 06:40:42 PM
0 Members and 39 Guests are viewing this topic.
GRANITEstateMP
Cutterboy,
I had a hollow log a few years ago.  It was just shy of 6', and about 18" around.  I plunged a few vertical slits up the length of the log, just bigger tahn the saw bar.  I then cut a little "snoopy" door/hole at the bottom.  set it up on a flat spot on the dirt driveway the same night we were having a bonefire.  Started a nice little fire in snoopy's door.  Not long after than thing was burning from the inside out.  The plunge holes made for some neat "lights". ZERO heat for the house, but plenty of amusement!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
cutterboy
Granite, my hollow ash tree would have been perfect for that. Too late now as it is all cut to 16" lengths. Might be good for bird houses.
the small ones are good to cook breakfast on.  set stones or metal rebar on the top to support a cast iron skillet or Dutch oven on to let it ventilate.
Resonator
Made some flower planters out of a hollow log a few years back, cut sections just tall enough to drop potted plants in. ffsmiley
BargeMonkey
 Iced in above Poughkeepsie, waiting our turn till morning. 1wk till freedom.
David B
Kinda chilly, getting down into the 30s at night. 😁
- davidwyby
Machine and welding shop day job, trees after work.
Peter Drouin
I have one, 20" dbh 20' long 12" hole from end to end W oak. I was going to cut it up for firewood. But there's nothing there,  Maybe I'll cut it up in 4' pieces and put it out in the woods for habitat, A rabbit might like it. ffcheesy ffcheesy
Maybe they will light it to roast their carrots on.  A Swedish Hare candle.
taz-smiley candle_smiley pull_smiley fire_smiley musteat_1 smiley_chef_hat
Kodiakmac
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
Big_eddy
Kodiakmac
There are some pockets of tall, straight cedar left in this area.  There is one tree on that load that gave me three 12' logs; the top log had an 11" small end diameter.
David B
- davidwyby
Nebraska
That looks really pretty but what is it?
Sheepkeeper
I'd say Sunshine Locust. Don't think that I'd want a true Honey Locust that close to the house.
The hurry-er I go the behind-er I get.
Rhodemont
Tulip Poplar.  Pic is 26" x 20ft.  In Upper left of pic you can see butt log 32" at base x 20 ft.  Good grief they were tough to get out on the trail.  My tractor and winch worked overtime.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Tom K
Took advantage of the frozen ground, 2 1/2 logs & 24" DBH
Rhodemont
Ground has been frozen so had to get them out before higher temps and rain coming in.
g_man
^^^^^ You guys are cutting some nice logs !   I have mostly junk to cut for firewood making the way for something better. Like this odd shaped 3 stemmed maple blocking the light from the nice pole sized red oak across the trail.
gg
But you are cutting the junk so the good ones can grow.
I cut junk too.
cutterboy
David B
The yellow wood tree was mimosa/albizia. I was hoping for Osage when I saw the yellow.
- davidwyby
PoginyHill
Cutting the pasture spruce on my property. Abandoned pasture 60+/- years ago grew these plus a handful of large white pine and some wolf maples. I'll have these cut into timbers for my own use since most sawmills won't accept them as a commercial product. Most of these are 80ft high and about 16-18" dbh.
Most of these are white spruce. Did most of their growing the first 25-30 years. Really slowed in the last half of their life. Guessing because completing trees grew up around them. Most have been nice sound wood. Have almost all of the 4mbf I'm looking for.
cutterboy
Those spruce sure do have a lot of branches. Must take a while to cut them all off. However, nice straight trees.
I also have a pasture that was abandoned about 60 years ago all grown up to trees. Mostly ash, red maple and black birch. Only the ash grew straight enough for saw logs so lots of firewood from the rest.
