Milling truck bed decking from river red gum
Started by David B, November 06, 2024, 12:08:10 PM
David B
I have an 8'x12' bed I want to deck with 1" boards. I have an oval log 21" dia  x 28" dia x 14'.  Euc cracks and warps a lot. I have been advised to avoid the pith. I'm wondering what the best way to mill it is. Maybe boards on the narrower side will twist less? right now the truck has 7" wide apitong boards, breaking down. Planning to screw it down green.
- davidwyby
Machine and welding shop day job, trees after work.
RetiredTech
The only thing I could suggest is that you use the driest wood you can find. Green wood is going to shrink and leave gaps in your truck bed. Good luck with your project. Share some pictures when you get it done.
Philippians 4:8
Branson 4520R, EA Wicked Root Grapple, Dirt Dog Pallet Forks, Woodland Mills CM68 Chipper
Echo cs-450 & cs-620p , Husqvarna 136, Poulan Pro, and Black Max Chainsaws
Partially built bandsaw mill
TimW
David B
Eucalyptus
Somewhere on here another fella said he screwed it down green to prevent warp. A little bit of gaps are ok, will let the dirt fall thru. Once desert dried, Euc is quite hard and hard to work with, and also full of cracks.
- davidwyby
RetiredTech
Well I learned something today. I thought you meant ERC and just hit the wrong key. ffcheesy
Philippians 4:8
caveman
Ian, surely has a lot more knowledge about Eucalyptus than I do.  There are many species with different characteristics.  The ones we have sawn were smooth barked, and the wood was red.  The pith would split due to tension, but the wood away from the juvenile wood behaved a lot better than I anticipated it would.
Caveman
David B
Progress
- davidwyby
You can see the pith check opening up in that 3rd picture. Basically the slab is going to split in 1/2. Not the end of the world, as you can (should?) rip 2 quarter sawed boards from it.
Because eucalyptus is such a huge family of trees, that are hard to ID, it's also hard to give advice. If you aren't worried about a bit of bowing / uneven gaps, then screw it down green and let it dry in place. It can't move much that way.
David B
The extras are going to be something pretty
Unfortunately, my wife says the color clashes with most people's decor. 🤦🏻�♂️😆
- davidwyby
David B
Screwing it down green and promptly coating with boiled linseed oil seems to have worked great.
- davidwyby
David B
- davidwyby
David B
That being said, I'm not sure quartersawing is worth the extra effort and waste for truck decking.
Found bed pics.
- davidwyby
Jack jr
Probably a bit late now, but with any of our eucalyptus trees, we only 1/4 saw them,as they cup and crack terribly otherwise.
Cheers Jack jr
