Old guy frustration
Started by Texas Ranger, June 17, 2025, 09:21:13 AM
Texas Ranger
VA gave me hearing aids, obviously for hearing loss (duh) and with the aides came a whole new morning regime that involves replacing the batteries if needed.  For those with good ears the batteries are smaller than an aspirin tablet with a smaller tape "handle" that needs to be peeled off. With ten thumbs this can be a challenge.
So, VA sent me a new supply of batteries with a note saying, "new child proof packaging". right, all thumbs has a new challenge.  Now you have to perform surgery to cut the battery out of a hard plastic package.
Obviously, the VA does not recognize vets can be old farts with 10 thumbs.
I hates child proof packaging.  I understand the need to keep button batteries away from swallowing kids, but I still hates them.  At first I said no, but later agreed to get rechargeable with my second hearing aids.  So far, so good.
Add to the child proof packaging, the shoplifter discouraging packaging of most everything else.  Kitchen scissors and a sharp knife are now requirements.   :veryangry:
I'm amazed that liability hasn't come into play with some of the packaging nowadays. There have to be injuries when people are trying to get packages opened. I know I've suffered minor cuts, but had a few instances of almost stabbing myself
I was hinting at the same thing.  It almost takes a chainsaw to get through that thick plastic bubble stuff.
There needs to be one end that you can scissor and slide the packet open.
I've found the shop bandsaw is excellent for opening those packages. If I didn't have it, I would have to use the sawmill. Would probably need a video from yellowhammer on the correct sawing patterns and band to use. ffcheesy
21incher
You may want to contact them and ask to have your aids switched to the rechargeable lithium  battery aids. Never have to touch batteries again and they are sealed so sweat and water do not bother them. Mine will go 24 hours on a charge with Bluetooth connected and I have severe hearing  loss requiring the big power receivers. I have had mine almost  2 years and battery  life has not shortened.  Just put them in the charger at night and ready to go the next  morning.  I think full charge  is 3 hours and half charge is 30 minutes.  Charger has built in batteries and can charge  the aids for 4 days without power.  Definitely the way to go. I bought  mine but a buddy was able to get a similar set from the VA so you should  check. Never  have to mess with batteries again and don't have to worry about jumping  in the pond while wearing them. Plus the charger is a great way to store them at night.
Texas Ranger
Thanks 21, VA has, I think, given a three-year life span on aids, but when the time comes, I will switch.
I think the worst is buying scissors, in a package that needs heavy duty scissors to open....  :wacky:
If I had a good pair of scissors, then I wouldn't need to buy a new set would I?
customsawyer
It's not hard to get frustrated with the VA.
www.thecustomsawyer.com
YellowHammer
I had some Duracell 2032 the other day that has a double packaging and bad taste coating to prevent kids from ingesting them.  They were difficult to open, I used three knives, some scissors and a fillet knife.  It wasn't an optimal process.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Raider Bill
Quote from: customsawyer on June 18, 2025, 06:48:02 AMIt's not hard to get frustrated with the VA.
The V.A. gives you a second chance to give your life for your country.
The First 72 years of childhood is always the hardest.
Texas Ranger
Quote from: doc henderson on June 18, 2025, 07:33:29 AMIf you buy in bulk like 6 or 12 from the amazon, they are in a plastic pouch and not hard to iopen and cheaper.  I am a Duracell guy. :sunny:
Amazon.com: Duracell CR2032 3V Lithium Battery, Child Safety Features, 12 Count Pack, Lithium Coin Battery for Key Fob, Car Remote, Glucose Monitor, CR Lithium 3 Volt Cell (2032 3V) : Health & Household
Thanks Doc, but I am a big fan of free batteries from the VA.  Going for the chargeable aids when the time allows it.
trapper
Doc I am with you on duracell  I have the least problem with the battery's in things corroding when I use  duracell
Tex. these are not hearing aid size.  Bigger than a Nickle and smaller than a quarter.  more for fabs etc.  even the controls I use for fans and light by remote.
Texas Ranger
caveman
Raider Bill, I'm glad I finished my first cup of coffee before I read your post, or I'd be wearing it.
On another note, a good friend and neighbor, who is a Navy vet, really speaks highly of the VA.  He goes over to Tampa, I believe.  He had some weird neurological stuff going on a few years ago that they evidently got sorted out.
The packaging that a lot of things are put in can certainly lead to trips to the VA or other health providers.  Y'all old men carry on.
Caveman
Quote from: doc henderson on June 18, 2025, 07:54:35 PMTex. these are not hearing aid size.  Bigger than a Nickle and smaller than a quarter.  more for fabs etc.  even the controls I use for fans and light by remote.
Metric size batteries.
2032 is 20mm dia x 3.2 mm tall. So coin size.  Common for computer motherboard clocks, so I have a pack on the desk.
That reminds me, I've got to get a couple more CR1632 for my car fob. Not the end of the World if it goes flat, but you have to pull the mechanical key out of the fob to open the door, then hold the fob on the start button. Better to have a spare battery in the glove box.
Chuck White
The 2032 seems to be a very popular size battery.
I have one in my bathroom scale and one in each of my ADT window and door sensors!
they seem to store ok, so I get them and a few other sized, by the dozen.  I got a variety pack for the house, so the family does not use mine all up and then I would be right back where I started.
customsawyer
I use the same 2032 battery a good bit around here too. Of course it is in a few different red dot scopes and not hearing aids though.  ffcheesy
That may be part of why we all need the hearing aids. ffsmiley fudd-smiley   :rifle: thumbs-up
PatD and I just spent a couple of days at the Cabin starting to get ready for the 4th.  My hearing aids went but about 5 miles from home I realized that I had forgotten the charger.  They started complaining about 1:00 and died about 2:00.  I was hesitant about removing them without having their secure storage "nest" so I finished the afternoon with ear plugs instead of hearing aids.   :uhoh:
I will need to research how to turn them off at night and back on in the morning.  Just never had the need to do it before.
TroyC
Just hold the button on the bottom of each aid down for a few seconds and they turn off. ffwave
  Kinda what I figured and I also suppose that the same thing will turn them back on. ??  Maybe they are now charged enough to find out.
Yup....it worked.    :thumbsup:
