Slabwood to kindling maker
Started by WV Sawmiller, June 14, 2025, 08:51:32 PM
  I debated where to put this. Here, General, Firewood (Probably where it should have gone) but decided it might get more visibility here.
  For a long time I have been thinking about buying a roller rack/table/assembly and making a table to cut waste slabwood and edgings into kindling and small firewood pieces. I drove to Blacksburg VA a week or so back and bought 2-10' aluminum rollers from a Craigslist vendor there,
    Today I got out and took a couple of measurements then made 2 rough sawhorses out of some short tulip poplar 2X4s I cut out out of a short butt log a while back. I cut the legs at 36" and made the I-beam top 48" long.
Nothing fancy just functional. Then I placed one of the rollers on it, centered it, and lag screwed into place with 2" X 3/8" lag screws I had in stock.
Basically I am thinking to just add some sides and make a trough, load it with scrap slabwood, push to the end and cut to length with a chainsaw. The wood will be loaded in and I will push the load to the end and cut in about 15-18 inch lengths for personal use. The rack is tall enough I can back my trailer or cart under it and let the wood fall in.
I was thinking I could lift the rig with my FEL and small tractor and move it but I suspect I'd bend the aluminum frame it I lifted it as it is. I am considering adding a couple of small wheels and tow or push it around the lot.
I noticed the aluminum frame of slightly over 4" wide and I tried putting a rough, full cut 8' 2X4  in the frame and see it is a near perfect fit. IMG_4356.JPG
Right now I am inclined to just cut 2- 2X4s to length, nail a 1X12 or such to both of them, then place the 2X4 in the slot and attach with 2-3 bolts on each side through existing holes already there. I guess I could add a couple of short 2X4's on the other side of 1X's for stiffeners and extra support. The 2X4's should stiffen the frame so I could move it with my FEL and tractor. I will have to keep thinking about whether to add the wheel to one end. I think I can get a pair of wheels for about $20 each at HF if I don't see something cheaper at the flea market.
    If it doesn't hold up and replace ever piece easily and cheaply as long as I don't damage the roller frame.
    I sell most of my slabwood at a dirt cheap rate and the customer loads. I could put the rig out by the slab pile and they could sut their own right on site if the want to. I am thinking mostly about my own use and 2 brothers who come buy and cut slabwood into 10-12 inch lengths.
The real question,... did you cut the legs on the sawmill?  ffcheesy ffcheesy ffcheesy     I am about to do the same for my 2-foot-wide roller tables, but I will leave the rollers and sawhorses separated to make it easier to move and get into place.  the stock legs on the rollers are too flimsy for the way I roll.  I will leave the top end braces off so I can nest and stack the sawhorses.
Doc,
   The sawhorses exceed the 32" max height on my mill so I precut them on my RAS and assembled them at my outdoor work site there.
    I considered keeping the roller and stands separate and will do that if necessary. I can always permanently install some long boats with wing nuts if I need to. Right now I only have the 4 lag screws to remove but will have probably 6 more bolts through the frames and sides as currently planned.
  I got back on this project yesterday and cut 2- 10' poplar 2X4 and a low grade 1X12 and 1X14. I marked and bored 3 holes in each 2X4 and 1X then placed the 2X4 in the slots on the roller, ran the bolts through the 2X then the 1X then tightened the nuts. That made pretty stable sides with a trough to hold the wood to be cut.
    To reinforce the sides I cut 2- 1' long 2X12's into triangles, nailed a 1' long 1X4 to one of the short sides of each triangle, placed the other short side of the triangle against the vertical 1X sides and nailed the 1X4 bases into the sawhorses. Then I nailed one 2.5" nail through the sides near the top into each triangle. This made a very secure brace on each side of the 1X sides.
Side view of finished roller "machine" You cn just see the 3 bolts through each side.
Open end view. Wood will be dumped into the trough and pushed to one end and cut off.
The weight and stiffness of the 2X4s and 1X side make i look like it will be easy to move with my FEL. Testing is the next step.
I went and sprayed some weeds and when I returned a local resident was inspecting  and reviewing my work.
