Operator Chip screen/guard
Started by Bullheaded, June 10, 2025, 08:47:58 AM
0 Members and 14 Guests are viewing this topic.
Bullheaded
I am curious as to what some of you are using for chip screens between the operator and the blade? I am thinking of using 3/4" welded screen with 1/4" hardware screen over that. I plan on hanging the "guard" allowing it to swing. Thank you.
Be thankful for every new day.
East ky logging
I have a piece of 3/4" expanded metal screen that swings or on hooks that I can remove if necessary. Best thing I've found so far is a forestry helmet with a screen face guard with earmuffs. It keeps all but the finest dust out of your face with the added ear protection.
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
Do you now have a framework above your circle blade to hang a screen? I like the helmet idea to cover the bases.
Ron Wenrich
I worked one mill that had a piece of glass with screen on the inside of the glass.  Easy to clean, but it gets dirty quickly when the sap is running.  It will also take a shot to the glass without shattering.  That comes from experience I had when a slab that came back to the headsaw.  It also would swing.
I would think that the 1/4" screen would cake up with dust.
Bullheaded
Here is a pic of the current state. I was going to make a swinging screen but wanted to see if there was a better idea first.
Bullheaded
Ron Wenrich
How much of a problem do you have with the sun shining on your blade?  I know that my not seem like a problem, but I have always noticed that the saw doesn't perform nearly as good as it does on a cloudy day.  Even in buildings with a roof, whenever the saw can shine directly on the saw, it will perform differently.
To overcome the problem without building a building, I put a roof over the top of the saw.  I used slabs as roofing material.  Perhaps you could incorporate your window with that type of structure.
What are you going to do to handle the dust?
Bullheaded
Ron,
I have read about and am aware of sun heating the blade. In time, I will build a complete sawmill shed. I just found (4) utility poles and hope to have them planted within a couple weeks. I eventually plan to build a conveyor for sawdust.
My priority shifted a tad yesterday when the grandson of my cabins original builder showed up with a (10)cord load of red oak firewood. Knowing I had the mill he brought several nice bolts in the load. I am anxious to throw one on the mill!
Woodside Kai
A piece of metal wire window screen works pretty well to keep the sawdust off your face.
taylorsmissbeehaven
Protos helmet. Even wear mine when I weedeat these days!
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
Bullheaded
Making good progress on the mill shed. Those 6x8" top chords are kicking my butt. Trying to cut everything that I can on the mill. The roof over the log loading station was designed so that I can rake snow off the solar panels.
Bullheaded
