Big Portable Job
Started by boonesyard, June 20, 2025, 10:36:59 AM
TimGA and 7 Guests are viewing this topic.
boonesyard
Hi All, it's been awhile.
Been a little crazy, retired my municipal construction company last year, still dealing with that. Found out it's easier starting a company (22 yrs ago) than it is shutting one down. Very excited about being able to spend my time with the sawmill and our wood products business. Although, after a year away from full-time work I have no idea how I had time to do it all.
99% of our sawing is stationary at our site. I've done a couple portable jobs in the past, not a lot. Got a call from a guy about 3 hrs away, just had 16 acres of virgin white oak and ash logged, looks like very nice stuff. About 150 10'-12' logs, approx. 23,000 bf.
I'm thinking hard about taking it on. He has help and support equipment. Wouldn't be a bad pay-day if everything goes according to plan. I usually charge by the hr. because my custom jobs are typically small and not very clean but this would be by the bf. Not sure how long it'll take, guess I'll know when it's done.
Thoughts??
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
   Good luck. Just figure your expenses carefully and charge accordingly.
    If it is a new customer you might want daily pay days so you don't get into a dispute or left hanging at the end of the job.
    My problem with distant jobs is if there is a break down I end up eating the travel costs so be sure to think about that and take every reasonable spare part you think you might need and the tools to fix the problem.
    In any case you will learns some lessons - what worked well, what didn't and what to do different next time.
When I was a few years younger, I gladly took such jobs and always made $$$.
Cover your bases such as travel/setup, return trips after the weekend, lodging etc, & payday at noon Friday to give you traveling time going home.
terrifictimbersllc
Price it so you want to do it. No one benefits if you don't.
boonesyard
How much you all charge by the bf on a larger project such as this? Region, log quality, help, support equipment are all variables that affect efficiency,  but I'm generally between $.40-.50/bf
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
I charge the same sawing rate, but I know going in that it will be more predictable and steady sawing for the entire job which means more $$.
Sadly I just declined a job this week that would have been very profitable.  ~60 miles away and probably 15-16Mbf.  I would have never declined that job a couple of years ago.
Quote from: boonesyard on June 21, 2025, 08:44:25 PMHow much you all charge by the bf on a larger project such as this? Region, log quality, help, support equipment are all variables that affect efficiency,  but I'm generally between $.40-.50/bf
I'm in a low cost area and charge $.35/bf and a daily milage fee of $1/mile one way. I charge $30 per blade for damage from metal. etc.
My hourly rate is $70/hr and I use the run meter for the timer - I don't shut the mill off between logs if sawing hourly. I do very few hourly jobs.
My bf rate is actual scaled rate at the end of the job. Anything under 1" thick is billed as one inch.
I go over all these rates/terms with the customer and make sure they agree and understand  before I ever start a job.
My rates differ greatly from Howard's above.  My bf rate is $.45bf, $2 per mile one way for travel & setup, $45 per metal damaged blades, and $125 per hour.  I very seldom saw hourly but when I do my hourly rate includes all time that I am on the job whether sawing, cant hooking a log, or distracted/discussing the sawing with the customer.  That time will generally be for a 7-9 hour day.  My "sandbox" job was a good example of hourly rate where I was sawing timbers.  It mattered not whether I was measuring and chainsawing logs to length, wire brushing the embedded sand from the bark, sawing, directing how the timbers would be stickered, or waiting for the borrowed sky track or skidsteer to be returned so I could go back to work.  Those days generally ran 9-10 hours per day.  I was in a commercial situation where the entire workforce was paid hourly, me included.
customsawyer
Howard, not trying to hurt your feelings, but you are doing yourself a disservice with those rates. MM's is more in line because he charges for lots of 2x material where he's actually sawing 1 5/8". I still think he's a little low, but closer. IMHO.
I know every area is different, and the logs sawed are different. However, low rates hurt all the other sawyers in your area, not just yourself. When I hear folks say they are in a suppressed area and don't think they can charge more, I always wonder if their area Walmart, Home Depot, or grocery stores are charging way less than they are in my area? Like I said, I'm not trying to step on any toes here. Just food for thought.
My rates for sawing are at $0.65/bf. This is dead stacked at the end of the mill. If I sticker the lumber then I charge even more, and I charge for the stickers. If they return the stickers then I will buy them back, if in good condition. They have to bring the logs to my site. This lets me use my equipment and increase production even higher. To charge these rates you have to be making a great product. One of my rules for my employees is if they wouldn't buy it, then don't expect my customers to pay for it.
www.thecustomsawyer.com
red
There have been many discussions in the past about Starvation wages
Resonator
If it were me, I would draw up a contract with all the rates and expenses clearly spelled out for them to sign, and get a down payment. I've done a lot of work on just a handshake, and it all worked out fine. But I've also learned the hard way with perspective customers suddenly changing their mind, and me losing the work because of it.
I bill by the hour on all sawing I do. But if you have good logs, good help, and good production, then board foot (plus expenses), may be the better way to go.
I'd also check how flexible their schedule/timeline is, if you have to plan for weather delays/breakdowns, etc.
If you do the job, as said bring tools, parts, and blades. Lots of blades. :thumbsup:
Here is the situation that I am in. (quote from Reply #7 above)
 "My "sandbox" job was a good example of hourly rate where I was sawing timbers.  It mattered not whether I was measuring and chainsawing logs to length, wire brushing the embedded sand from the bark, sawing, directing how the timbers would be stickered, or waiting for the borrowed sky track or skidsteer to be returned so I could go back to work.  Those days generally ran 9-10 hours per day.  I was in a commercial situation where the entire workforce was paid hourly, me included."
Below is a message that I just got from that "Sand Box" customer that I described above:
Hey Mr Lynn how are you doing?
This is XXXX XXXXXX
Can either you or your son come to Wellington and saw up about 5 truck loads of logs into columns?
Man I hope all is well with you
The above job sawing 5 log truck loads of logs into timbers would be a low labor high paying job.  Just guessing probably 2-3 weeks @ $125 per hour, half of that time sitting, waiting, and with the clock ticking.  He is ready now, just wanting to know when I can come.
I passed this job off last year and am now waiting to hear from that sawyer and find out what is up.  I have a call and a text in to him.
I was able to reach the sawyer that I pass jobs off to and he was excited to get the job/work.....again.
Stephen1
Quote from: terrifictimbersllc on June 20, 2025, 06:38:58 PMPrice it so you want to do it. No one benefits if you don't.
I'm a full believer in this. I love the sawing and everything I do with the Buisness, but if I'm not making money it's not fun anymore. You might as well go fishing or play golf.
I do all my sawing by hour. I am going to raise my rates this fall. I am at $135 hr, $1.75 kilometer  both ways , If I return the next day it's at $1 a klm, support help is billed at $40 hr for travel and work. I bring my own labour on %75 of the my jobs.
I like to make sure I am making $75 hr for myself.
all this in Canadian $$
boonesyard
This is all great stuff, I accepted the job. Everything will be cut in to the largest beams we can get from each log. He has 2 people to help full time with a large skid steer to keep the mill fed and take the cants away. They will handle all stickering/stacking. We have a signed contract at $40/blades per foreign strike, $.55/bf or $125/hr on the job, whichever is greater. That way I'm protected if his help is not there, is slow or breaks down. Travel is $2.50/ml one way. He was very happy with these rates, just glad he got someone to do the job.
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
That is a very fair agreement to both parties.  You will do well.   :thumbsup:
Andries
The way you've protected yourself from the hired help not showing up is a good business detail.
Question re the side lumber from sawing Timbers - will it be used or just be slab waste?
LT40G25
Ford 545D loader
Stihl chainsaws
Stephen1
That sounds great. A good rate either way.
What about travel each day? Are you staying in a hotel?
boonesyard
Off cut slabs will be firewood. We'll be staying on-site in our motorhome
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
cutterboy
Boone I'm happy for you. It looks like you did well for yourself and your customer.
Stephen1
Now we need some pictures!
boonesyard
We've booked it for the week of August 11th and get some pics if the weather holds. Been getting a lot of rain regularly, but nothing compared to what those poor folks had to deal with in Texas and N. Carolina. Just awful
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Stephen1
How long do you think it will take?
