Anyone experiment with alternative energy?
Started by Danny_S, December 12, 2005, 09:32:42 PM
Danny_S
Anyone around here like to build windmills, solar power, hydro power, alternative fuels, burn waste vegetanble oil, ect..ect..  ???
I am experimenting with a burner unit that will burn waste fryer grease (veggie oil). I have in the past help install a factory built boiler that will do just this, and has been burning it for about 2 years now. We found alot of faults with the machine but in turn we have made the system better. It heats two - 100' x 30' buildings and a 4 bedroom farmhouse, plus all the hot water.
I also want to build a windmill, from scratch..
Handy link to some homebuilt projects..
www.otherpower.com
Plasma cutting at Craig Manufacturing
OneWithWood
I have been actively researching brewing WVO to make bio-d to do just what you have done.  Did you purchase a dual fuel boiler or convert an existing one?  I just priced a dual fuel replacement for my Central Boiler and about had a coronary when I saw the price  :o
I have not set up my appleseed style still because it is too cold to process.  Come spring I hope to be up and running.
I sure could use some advice and I would appreciate it if you would provide some detail of what you had to do to get the boiler to burn bio-d.
Some Qs:
Is the boiler dual fuel (wood or oil, wood and oil) or just set up for oil?
How many gallons of bio-d is needed for a heating season?
What do you do to keep the gel point low?
One With Wood
PawNature
Built a Moonshine still... Ahemmmm I mean alternative fuel distillery once. 8) ;D
GOVERMENT HAS WAY TO MUCH CONTROL OVER OUR LIVES!!!!
thedeeredude
Yeah, I've dabbled with alternative energy.  I tried walking once instead of driving.  Let me tell you, its not what it's cracked up to be!
Modat22
One of the niftiest alternate ideas I ever saw was a methane generator. It was a big tank with the bottom cut off that slid over a slightly smaller tank. There was a seal around smaller tank.
Waste, kitchen scraps, animal scat etc was thrown in there. As the methane was produced the big tank would raise. The gas was used to provide for cooking fires.
remember man that thy are dust.
Coon
Use of alternate energy..................  H**L YEAH. :D
Next spring we are converting our power system over to Solar.  We have our proposal written up for the bank.  I do not see any reason as to why they would not fund our project.  We are willing to pay a loan payment equall to what we pay for power at this point in time.  We would like to set up with enough power to supply our house, garage, kiln (which isn't built yet), and saw shed.  We already have our own well, and are heating/cooking with wood.  All that leaves us for utility bills is our telephone, which would greatly cut our expenses. :o :o
Norwood Lumbermate 2000 w/Kohler,
Husqvarna, Stihl and, Jonsereds Saws
edsaws
Other than my wood insert no. I watched a video on bio deisel and couldn't justify the cost, labor, time to make it. I still hope that someday fuel cells will become a reality. I'd love to get one of them and sell what I don't use back to the power company  8). But I don't think that'll happen anytime soon. I also thought about solar since my house faces north/south that may be a possiblity some day.
Modat22
I'd like to get my hands on one of those 50 hp sterling engines. I saw a few on the discovery channel rigged up to burn sawdust and pushing an electric generator, If I remember correctly they where around 80 percent efficient and very reliable. Mostly used in 3rd world countries and cost prohibited in the USA
Paschale
I just heard on the radio on Sunday about some "vegetable oil wars" in Portland, OR.  There are guys converting their diesel cars over to vegetable oil, and so all the restaurants are being approached by these guys who filter the old stuff out and sell it to these guys. Quite a little war brewing over there. Apparently, Diesel designed his original engines to run on peanut oil, which I didn't know until I heard that.  Apparently there are about 3 billion gallons of veggie old used in restaurants across the country.  That would run a lot of diesel engines!  Just wonder if your exhaust smells like french fries...   ;)
I've read you can convert oil furnaces to run on Waste Vegetable Oil...is this easily done?
Y'all can pronounce it "puh-SKOLLY"
farmerdoug
I converted a pot type oil furnance to burn waste motor oil to heat a greenhouse once.  The problem I had was trying to find used motor oil to burn with regularity after I burned up the waste oil I had stored on the farm.  I did not realize that ten years ago that there were that many waste oil burners out here until I tried to locate the waste oil.
Farmerdoug
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Danny_S
The boiler we installed burnt STRAIGHT used vegetable oil. We did not convert it to biodiesel. This is a pic of the burner unit.
The unit on the left is the oil pump. In the housing is a D.C. motor that has a potentiometer switch on it so you can control the oil flow to the burner. The oil pump itself is not any different than a regular oil furnace oil pump. On the end of the burner unit (right) is the air compressor. It also has a valve that can be adjusted to regulate the airflow into the burner nozzle. The main housing and blower fan are te same as a regular furnace. The secret is the oil/air heating block inside the barrel of the blower assembly. There is a alumium block about 10 inches long, with passageways drilled in it so the oil will go the length of the block twice before it reaches the nozzle. The air does the same. The block has a 400 watt element in it that starts before the furnace starts to preheat the oil before ignition. The nozzle mixes the oil and air and is fired with the electrodes the same as a regular furnace.
We let the oil sit in a hot room that is about 120 degrees for a week or so. The crap and crud in the oil will settle to the bottom of the barrel. We pump off the good clean oil and it goes through a 10 micron filter before it goes in the storage tank. There are hot water heat elements under the tanks to keep them warm. We found that we had to keep the copper lines and the final filter, the pump unit and the line going to the burner all warm to keep it from congealing on the cooler surfaces of the filter casings.
The guages only lasted about a month, so we replaced them with liquid filled ones, they are much more accurate and dont "bounce" like the other cheap ones did. There is a small plastic line that comes from the compressor that goes into the burner, that we had to replace with copper because the compressor generated alot of heat and melted it.
THere are other things that we did to it to make it work better but will be continued later, got to go get the wife!
This is the site that supplies this burner.. www.econoheat.com
toxedo_2000
I made a watermill 11 or 12 years ago. A big wheel 8 feet in diameter connected to a car alternator, charging 12 volts batteries. An inverter was plugged to the batteries and produced 110 volt. It worked well until it began to be affected by moisture. But 3 years ago I had to replace that watermill with a little home made turbine with a home made Pelton wheel, just 6 inches in diameter. With help of few friends, I had to pull up in the mountain 1800 feet of carlon pipe, up to a little lake, at 225 feet of denivellation. Now, it is working very well and I produce around 300 watts/h, 24 hours a day. I use it at my remote camp. You can look at a QuickTime film I made at the time I installed my watermill.
http://www.tuxedoproductions.com/page4.html (wait for the film to dowload entirely before trying to play it)
The mill is now in a covered place that i built over the stream, and plugged to 8 batteries with a 2000 watts capacity each.
Toxedo
Toxedo
Why walk when you can fly
crtreedude
Energy is so cheap here that the return on investment would be a long time for almost anything - except perhaps using wood scrap to run kilns. Costa Rica sells hydroelectric to other countries it has so much. Lots of rain, lots of mountains makes for lots of power.
I guess I do use alternative energy in one way - it is called a horse.  ;D
So, how did I end up here anyway?
pappy
WOW toxedo nice video clip... 8) 8) 8) 8)
I can't read French to pretty good but you are WAAAY up north... you gotta be real close to the N. Pole uh??
crtreedude he's the one to talk to about helicopters   ;D  that's got to be the best way to see the sites as toxedo does...
oh ya welcome toxedo
toxedo_2000
 :D :D :D Not really near the North Pole
It is 1 and a half hour flying time, north of Montreal, Quebec. Cannot go with a vehicule on wheel 'cause there is no road. But it would take about 9 or 10 hours on the existing roads to get few miles from my cabin.
Thanks for the comments
Toxedo
Toxedo
toxedo_2000
I wanted to add few pics of what I had try to explain with words. Pic worth a thousand words no ?
Remember, everything there came by floatplane or helicopter, except the logs and boards. No ground road there.
That is the first watermill I built 11-12 years ago. It is oak and plywood. I made it in my shop, then unmounted it to put it the floatplane I had at that time. Then reassembled it on place.
And there is the second one, 3 years ago
Under it you find a little wheel
And the nozzle that bring water with pressure (68 PSI)
We had to bring a very long pipe (carlon, 1800 feet) This pic shows how we bring that to the remote cabin. We had to tie most of it on the floats of the Beaver because it was to big to go inside.
In flight.
I was not far in my helicopter
We pull the 1800 hundred feet by length of 450 feet to a little lake at a level of 225 feet higher
An there is the watermill at work
later I built this house for the mill
Here it is inside over the stream
This pic shows the batteries where i stock the energy
Here the DC is transformed to AC and and from there it goes to the camp.
We even can watch TV. The antenna is at top of a tree.
In the living room
And the kitchen
The thing i like to think is that it is a little stream that roast my toasts and bring me TV an everything else.
Hope I did not bother you with my little story
Regards
Toxedo
Toxedo
Skytramp
I have two uncles that run a garage in a small town near me, they store all their used oil in a tank uphill from the garage.  They ran a 1/2 inch steel line down hill to their wood stove.  they then ran a small pipe into the old cast iron stove  they controll the flow with a water valve, just a drip on the burning wood produces a lot of heat and gets rid of the used oil.
     Don't know what the EPA would say, but it works for them.
Skytramp;
Growing old is inevetable, Growing up is optional
srjones
Toxedo, that is waaaay cool.  (très fantastique!)  :o
I think micro-hydro is definatly the way to go if you've got the water to do it.   If you don't mind my asking, how did you make the 'paddles' like the one you're holding in your fingers?  Also, at how many RPMs does it run and how is it regulated?
Along the same lines, but I'm not sure if would be considered alternative energy, is the ram pump.  It's low tech (only two moving parts) and pumps water from point A to point B using gravity and hydraulic pressure.
I hope to do both someday.
Everyone has hobbies...I hope to live in mine someday.
Deadwood
You didn't have a project on your hands Toxedo, you had a adventure building that. Planes, helicopters, piping and machining, wow that is quite the story. Thanks for sharing.
crtreedude
that is wonderful - I have to admit my dream has always been having a cabin in the woods. Granted, I can't complain - we have a square kilometer of plantation and rainforest now - but NO CABIN!
Once Harold gets here - it is on the list.
sprucebunny
That's really great, Toxedo  8)
I'm going to build something like that. ;D
Fla._Deadheader
That is really cool.  8)  I especially like that Cabin. Good job all the way around.  Thanks for showing all the photos.
  We NEVER get tired of photos and stories around here, true or otherwise. ;D :D
  Bookmark this page, Fred ??  ::) ;D ;D
OneWithWood
Danny, thanks for the write-up and picks.  I look forward to hearing more about the set up.  Straight WVO sounds good to me.  That would mean I would only need to brew enough bio-d for my equipment.
Tux, great story and pics.  Thanks a lot. :)
One With Wood
toxedo_2000
Quote from: srjones on December 15, 2005, 02:36:37 AM
Thanks to you and all the members
All explain How I made the paddles that I call spoons:
First a friend of mine who is a my blacksmith teacher, made a die to form a half sphere.
Then I put that on my press and made a lot of them
After that I used an other tool on the press to form ... I dont know how to call it... but it ressemble to a pair of bumps  ;)
Third thing to do, was to fill the back of the spoon with weld, and carve one end in a "W" form. I also had to sharpen the interior fishbone to make it very sharp so the water jet would be cut in two when hitting the middle of the spoon. That action is made for every single 24 spoon. Time consuming since it is a carving job. It is made with different sets of files and small grinding wheels.
I welded all the spoon on a 5 inches cicle (made of an old saw) divided in 24
After that I put the wheel on the iron mill, and grinded it while it was turning. (sorry, no picture of that part of the job) I did that to equilibrate everything and minimize vibrations. You see, that wheel can turn very fast with the water pressure, up to 3500 t/m average with a nozzle 3/8 inch wide.
I did not invent that kind of wheel as you know. It is a "Pelton" wheel. An old concept and design. It is supposed to be the more efficient profile for that kind of watermill. I just looked at photos on the net, and tried to make the same. I could have buy the wheel for 5 or 6 hundred dollars, but Naaaa ! I like to do the things myself.
Next question ?  ???
Ho yes, somebody was asking how it is regulated. Well, the pressure is constant, and the nozzle is always the same giving a constant dynamic pressure. (68 PSI for now) That can be altered by moisture and algues forming inside the pipe, but i manage to clean it a couple time during each summer.
Toxedo
One more pic
At the top, an intake (a plastic barrel with hundreds of small holes) is intalled to prevent any strange big thing to enter and clog the pipe. That pipe took 3 days to get up to the small lake. But at the end, it was there
Toxedo
Radar67
I saw this Pelton Wheel in Lead, SD. Thought the group might like to see it as well.
The diameter was about 60 inches. It was used to generate electricity for a gold mine in the early 1900s.
Stew
