Fast drying polyurethane
Started by ohsoloco, April 30, 2007, 08:00:12 PM
Well, I am trying not to be a pesterer.  I figured it was a pons asinorum ;D.
PC-Urban-Sawyer
Now, now WDH. I don't care what kind of bridge you build, any fool, even if his name was Euclid  ;D, would know that some things just take a while to figure out. And sometimes life gets in the way...
Just so you know the context of pons asinorum in my post, it is a problem that is too difficult to be solved with the level of information available.
Pons Asinorum (Latin for "Bridge of Asses") is the name given to Euclid's fifth proposition in Book 1 of his Elements of geometry:
In isosceles triangles the angles at the base equal one another, and, if the equal straight lines are produced further, then the angles under the base equal one another.
Pappus provided the shortest proof of the first part, that if the triangle is ABC with AB being the same length as AC, then comparing it with the triangle ACB (the mirror image of triangle ABC) will show that two sides and the included angle at A of one are equal to the corresponding parts of the other, so by the fourth proposition (on congruent triangles) the angles at B and C are equal. Euclid's proof was longer and involved the construction of additional triangles.
It takes its name as the first real test in the Elements of the intelligence of the reader and as a bridge to the harder propositions that followed. Its location in that text is much more advanced than where the problem is posed in present-day geometry textbooks for high-school students.
After PC-Urban-Sawyers response, I realized that my post might be intrepreted as an insult or demeaning, which was not the intent.  No offense intended :-\.
jpgreen
Hmmm... I wonder what that wipe on poly would look like on those Asinorum's?..  ;D
TexasTimbers
Quote from: metalspinner on May 05, 2007, 01:48:22 PM
After sanding down my third coat, I usually spray it down with a can of aerosol poly.
I might be doing something wrong but I find that the sheen in the aeresol cans do not come close to the same alledged sheens in the can. That picnic table I made for the VFD auction - I had to add nother final coat over it because I tried to use the high gloss spar urethane out of the can. It looked semi-gloss at best.
But as I say I may have been doing something wrong.
ohsoloco I don't know if anyone has mentioned it yet but we really like pictures here on the FF ;D
The oil is all in Texas, but the dipsticks are in D.C.
PC-Urban-Sawyer
Quote from: WDH on June 07, 2007, 07:52:29 AM
My response was intended to be somewhat of a joke based on my quick research into the meaning of pons asinorum. I hope noone took it otherwise.
It's always good to learn something new. I think I may a learned (again) to think a bit harder before putting my words down in a post.
PC-Urban-Sawyer
metalspinner
QuoteInsert Quote
I should have mentioned that I only use semi-flat poly.  I have not tryed this technique with any other sheen. :-\
While we are talking about sheens...
If I use a satin coat as a base, then apply a gloss over that base coat once dry, how will that effect the gloss appearance?
TexasTimbers
That much I do know. The high gloss over semi or satin/egshell will  be jsut as high gloos as on top of another high gloss. I did this on the picnic table in fact because I started out with a can each and planned to use the high gloss last from the beginning. You can't tell the differnece.
ohsoloco
I almost feel bad posting these photos...I think they're horrible  :-\  This computer monitor stinks and makes pics look dark, so I'm not sure exactly how pathetic they really are, but having the bed sitting under open windows certainly didn't help  :(
Walnut bed with hybrid poplar slats to keep the boxspring from slipping off the 1-1/2" wide cleats inside the perimeter of the bed.  These are the only 4 pics I took.  The live edge headboard showed quite a bit of curl (the actual bark side of the board is facing the wall)...can you see any of it  ???
Ohso,
The curl is really beautiful.  You did a great job on that bed.  That live edge headboard is very creative ;).  I like it  ;D.
Pics look good, but # 3 and 4 show the grain in the headboard the best.
Nice design to show off the walnut headboard.
Are the rails 3/4" walnut?
pigman
 8)
Looks great ohsoloco. smiley_thumbsup   I really like the natural edge headboard. I will have to learn to build unique furniture like your bed.
Bob
ohsoloco
Thanks for the kind words  :)  This monitor must be worse than I thought.
Yes, the rails are 3/4" walnut, and I found out that is the absolute minimum thickness to use on the bed rail fasteners that I used.  I picked two of the flattest pieces in the lumber pile that I could so I could completely flatten one face on the jointer and still have enough thickness to end up with 3/4" out of the planer.  In hindsight I should've just planed both sides to get the thickest pieces I could, since they moved after planing anyway (they had maybe 1/4" of sweep along the face of them).  Had to build a jig to fit over the ends of the rails to rout the mortises for the fasteners, and there was maybe 1/16" of meat on either side of the mortise (luckily they only had to be about 3/16" deep).  Slipped with the chisel once and took a little slice off the face of the rail, but was able to glue it back on to a virtually invisible fix  ;)
Wish I had a pic of the foot board.  There's a nicely centered arch of sapwood on the bottom edge.  I can't see cutting an arch into a perfectly nice board when nature can do a better job than me.  The customer had a big grin on her face when I set up the bed, so I must've done good.
Sprucegum
Yes, I say you done good, and the pics aren't too bad either considering the light you had  ;)
I built a bed with slats like that and just threw the mattress on, no box springs.
Nice looking bed ohsoloco. I use water based Varathane - Diamond Wood Finish on softer wood. Well I say I use it, but it's a new product to me and I only built a couple items last winter with it. I'm careful with the foam brushes because if you reuse between coats you can get foam specs in the finish.  smiley_furious3 smiley_crying
I do like Minwax products, just apply as instructed and things should come out fine.
