Portable Winch
Started by aniakhenry, June 01, 2007, 01:59:15 PM
treetech
It's not quite the same but close. I think the mighty mite is geared down a lot more than the yankee yarder but are the very same idea. I found a guy handy home that has one and I am still trying to get a picture.
Dan_Shade
Look what I found in the FF gallery:
lots of dull bands and chains
jpgreen
treetech
Hi All
I have put some pics of a yankee yarder in my gallery. I tried to post them but ran out of time. This yarder is not quite the same as the plans I have sent out but it is very close. These are great little winches and are easy to build. The modification I did was my engine didn't have reduction gear installed on it so I put in an extra shaft to slow the cable speed when winching in. This caused a lot more friction when pulling the cable out so I had to come up with a way to freewheel the cable. You can see this in the last two pictures.
Treetech
Blue Sky
I have got a Finnish Winch, the radio TIR.  Pulls 16'-24" diameter logs any way you want them.  It is a 13 hp, gear reduction of 13 to 1,  two 5 wind drums that multiply pulling power.  Check out my posting.   Enchanted Forester
maple flats
As far as cutting ahead and staging logs to pull in winter I have found it harder to pull them after they have set and frozen down even if only on cribbing and gotten snow piled on and around them. I like pulling in winter, fresh cut logs on a good snow base. I pull most of my heavier ones with a 25HP 4x4 tractor with FEL and 3PH log arch on back. If logs are heavier I load the bucket to hold the front down. I have chains front and rear, roll bar too, and I drive rather slow with one hand on the 3PH control and one foot resting on the tranny just over the clutch. Pulling with such a small tractor requires extreme caution because the front can jump up suddenly and you MUST be ready to react properly and not panic. On my arch I run 2 chains, one to lift and one from the log to the drawbar which helps prevent walking the tractor out from under the load (flipping)
Firebass
Not exactly what you had in mind but I had to post anyway.
http://www.ssindustrial.net/donkey.jpg
Steve
jpgreen
That's a cool winch.  A guy at a logging show had one running.  Pure cord wood and steam..  8)
I bought one heck of a winch from a friend of mine last week.  It's a 12k with 3/8" cable that came off of a roll deck tow truck.  Beefy starter motor powered angle gear drive.. .   :)
