How do I stop the "Wave"?
Started by MotorSeven, May 30, 2009, 08:20:10 AM
MotorSeven
I owed the neighbor a favor & he needed some lumber to finish a shooting house for his 600 yrd range. I sawed up some free logs into 2x6's & 1x6's. Most was Poplar(reeeealy like sawing poplar 8)), and the other log was Pine(we call it Jack pine....not white). Well, I kept getting a wave in the pine, even when edging I had waves as much as 1/4". I was using plain water. The poplar sawed perfect, so why the wave in the pine....not good enough lube, dull blade, tension too low or high.........operator error?
Sorry for the rookie questions, but I am sure to have more as the sawdust flys......
RD
WoodMizer LT15 27' bed
Could be any or all of the suggestions you gave yourself, but my first guess would be pitch buildup on the blade.  Pine is tough to saw.  There is such a vast difference in the hardness between the early wood and late wood, the saw trys to follow the grain.  It takes a really sharp blade.  Sawing parallel to the pith instead of the bark might help too.  Even a circle mill will try to follow the grain, especially on those with wide growth rings.
MotorSeven
Ok, I'll try a fresh blade and some Dawn dish soap in the water tank next time. I have to say that the Woodbug CSM cut that stuff perfect every time.
Hmm, so there is a reason Poplar is pop{u}lar...... :)
RD
MotorSeven
Oh and one more thing. I am going to order a Logrite for turning on the mill. Peavy or Cant? and I'm 6'4" so I am thinking 60"er?.
Ok that was two more things.....
RD
peterduncan
I have had the same problems, but with Spruce. The wood is so soft at first and then it hits an area that tough as steel particularly in the knots. The blade "panics" and wants to run away. We have used cooks blades with pinesol and a slower rate of cut. It minimizes it but doesn't alleviate it. We have to after- saw and plane
Quote from: MotorSeven on May 30, 2009, 08:58:30 AM
RD
Havta remember that one.   :D :D :D
John Bartley
The problem is likely the set of the teeth.
For softer woods like Pine, Spruce, Poplar, Basswood (especially when they're knotty), my bandsaw likes to have a set in the 0.028" to 0.030". That's on a 0.042" x 1.25" saw band. For hardwoods like Maple, Ash and Oak, I can saw with as little as 0.020" of set. In Pine etc, no matter how sharp and clean the band is I get waves with a narrow set. With a wide set it doesn't matter how dull or dirty the band is, it cuts straight (just slower and harder).
cheers
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
nas
Quote from: MotorSeven on May 30, 2009, 09:03:38 AM
RD
Order both, find out which one you like better, then give the other one to me! :) :) 8)
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
ladylake
 More set like mentioned and give some 4* hook blades a try, when I saw tough wood thats all I use.   Steve
I like the peavey,with the point.You can pry logs apart with it and stick it in the ground so you don't have to bend over to pick it up.But this is what I grew up with.Others like the cantdog.
moonhill
I agree with the suggestion of proper set.  Try a new band with more set and it should be fine in the pine. Soft wood releases tension in the cell structure and you get a larger chip than hard wood, or something like that, it is obviously larger and you need a bigger path to clear out the sawdust.  Also the wider the log/cant the more set is needed.  Poplar is an odd hard wood it almost acts like soft wood, unlike oak or maple.
DanG also had an interesting point with sawing parallel to the pith not the bark, there could be something there.
Tim
This is a test, please stand by...
wdncno
You might check your track rollers.  Sometimes sawdust or the stringy underbark will get stuck in the grooves and put the wheels out of round and that will give you the "wave".  An eighth inch of gunk in the groove of a 3" wheel will give you a rise about evey 9".
G-sawing
I use diesel for coolant, it cuts the tar well. If coolant was the problem it would wave all down the log. I think check your guide rolller if you have them, perfectly flat with bed. Set is a big one, on pine I try to use .025 to.027 also go very slow on entering wood. My guess is the wave was at the begining foot of the cut??? Give your blade a chance to stablize a second or two, you can tell from the dust out when it is really getting a hold, then go on with it. My experpienrce is if you enter pine slow once blade stablizes you can cut the rest almost fat enough to drag down the motor. Some pine is tough if the grain is tight.
Should you find your self in a fair fight, you're using poor tactics.
MotorSeven
Y'all rock! I am going to copy this & keep it for the next pine log. I have a 16" 20'er 2 miles down the road I need to go get, and a ton of them on my property that need cutting. Every time we get a really good wind storm, it looks like pick-up-sticks where the beetle killed and the good ones slam into everything on the way down. Most of mine are 20"+ since the logger in 1998 left them all, only taking the "good stuff". My poplar is almost ready for harvest, so I do have plenty of timber for the house.
RD
ladylake
 Are these pine logs real dry? If so run a lot of set, I've found that the blades that might have overset a little work the best in dry pine.    Steve
pineywoods
ditto what ladylake said. Above all else, you need lots of set. I saw mostly pine on my manual woodmizer, and I run as much as 30 thous set. Even when the blade gets dull, it will still saw reasonably straight if you have plenty of set. lesson learned the hard way, don't go adjusting on the mill until you are  absolutely positively certain the blade is not the problem...
Warren
I have a peavey and a cant hook.  I prefer the peavey for the same reasons as thecfarm.
LT40SHD42, Case 1845C,  Baker Edger ...  And still not near enough time in the day ...
park ranger
I bet if you look at your blade you can see the pitch that is making it wave.  I've used the water drip on the woodmizer I have and water doesn't cut the pitch like a solvent like diesel.  I cut a old growth western red cedar today, just slabbed it into 3/4" so a lot of the boards were at least 2' (guides out all the way).  I used get this...my dirty paint thinner (varnish) out of a spay bottle.  Every so often I give a couple squirts.  To cut the log I probably used 1/3 of my spray bottle if that.  It's better I run my backhoe on diesel than the thinner ::)
ladylake
 A blade built up with pitch will wave with any kind of wood. Cutting dry pine a blade with too little set and perfectly clean will wave and if you haven't tried 4* or 7* hook you should. I run 4* most of the time but buy my blades with 10* and just run them in easy to saw wood then sharpen at 4*.   Steve
bandmiller2
RD,I have and use boath peavy and canthook,usally use a cant hook to turn cants on the mill[surprise] and the peavy to move logs around,but they will pinch hit for each outher.Sometimes the point on the peavy gives you a pry point to move things around on the mill.Have either just long enough to do the task, nothing more agrivating than a long tool and a low roof.You should have boath, peavy longer.Frank C.
