The season for milling??
Started by bikedude73, September 23, 2009, 03:40:32 PM
bikedude73
Just getting into this and was not sure if the info I got about "the season" for milling was fall and winter.  Any insight would be helpful for my business planning..... :P  Thanks to everyone on here for all your help
tyb525
For me, it's year round. I prefer cooler weather but not below freezing, that way I don't have to take the water jug in every time I'm not sawing!
Banjo picker
The bark stays on the logs better in the winter...not as messy around the mill ...when the sap starts to come up in the spring it makes the bark turn loose esaier on some species...Tim
Dave Shepard
I like sawing in colder weather better. I can be lazier about dealing with dead-piled lumber. I also don't like to be out in the hot sun. I must say that below 20 F becomes a exercise in decreasing returns on investment of energy. I saw a lot of eastern white pine, and it will stain and mold pretty quick in the warmer months. I do saw year round, with each season bringing it's own challenges. Years ago a lot of farmers were loggers, sawyers and mill hands in the winter. Made sense, and some extra money.
Milling in cold weather is supposed to keep you from having to deal with so much runny sap, stain, insect damage and makes it easier to move logs if you have snow and ice (I only heard that), so it's easier for logging too.  I guess frozen ground gets you into swamps that you normally couldn't reach and frozen roads will carry more weight with less damage.
It doesn't get cold enough down here in Florida to make that kind of difference.  What it does is keeps us from having to deal with 100 degree temperatures and mosquitoes.  We also get a break on the insect damage and blue stain isn't quite so quick.
We saw year round and just adjust our efforts to match the temperature.   In the winter, we run in and get by the fire and in the summer, we go get in the shade or the air-conditioner.  It makes production pretty much even itself out.  :D
You will probably find, unless you are buying logs from loggers who control your accesss, that the best time to mill is as soon as you can get to the logs.  You just learn to live with the aggravations of the seasons.  :)
OneWithWood
If you are aiming to be a portable custom sawyer type the best time to mill logs is when the customer wants it done.
One With Wood
Chuck White
All of my milling is mobile!
So, I have to be able to access the customers logs and in winter's deep snow, that isn't always possible.
Besides that, if it's below freezing at mid-day, I'm not sawing!
I usually start sawing around mid-April and quit around early-November with an average production of around 60,000 board feet!
red oaks lumber
we saw year round, winter time  the customer plows snow before we get there. the only time  i can't saw is colder than minus 10 f the board freezes right back to the log, but that is still better than 90 deg.
Papa1stuff
No freezing is better than 90deg! ;D ;D
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
ARKANSAWYER
  I saw year round and like 90 to 100 best.  It thins out the whimps real quick and the boards dry faster.   It is hard for me to move with "layers" of clothes on and you know us hillbillies we hardly wear shoes.   Winter's bad weather means I have to keep more logs in stock which means I have more logs then normal that will not fill the orders I am sawing.
ARKANSAWYER
Papa1stuff
red oaks lumber
up north here,  men are men and the women are too!
Papa1stuff
I used to live up north and from what I ved seen a lot of the men have moved here where it is warm smiley_clapping and Women too! ;D
bandmiller2
I would rather the snow-en than the blow-en but geography aside winter is the time for milling pine no blue stain.The only pine we cut in the summer is for barn board or fence.Of course me and old tom are spoiled rotten lt70 electric ,radiant floor heat,mercury vapor lighting and enough room to keep several days cutting under cover.Frank C.
Fall and Spring seasons are my busiest times.  When it is below freezing, I start a little later in the morning, and when it is over 100 degrees, I start by 6:00 AM and knock off at around 1:00 PM..... :)
Frickman
I saw year round. The markets for high quality hardwood grade lumber are usually better in the winter months because of stain issues, and my markets for barn and utility lumber are usually better in the summer during construction season, so everything seems to even itself out.
If you're not broke down once in a while, you're not working hard enough
I'm not a hillbilly. I'm an "Appalachian American"
Retired  Conventional hand-felling logging operation with cable skidder and forwarder, Frick 01 handset sawmill
Pretend farmer when I have the time
Coleman
Most sawyers here in Canada prefer winter/early spring and fall sawing - esp when sawing Pine.  Pine Beetles and moulds are difficult in the warm summer months.
If you do cut pine in the summer a constant water sprinkling over the pine will keep the bugs and moulds off.  Then right after cutting, soak the cut lumber in a fungicide and let it dry...  Otherwise you'll hear the Pine Beetle larvae croaking from the logs and the blue moulds flourishing.
Fla._Deadheader
I'm with Arky.  8) 8) 8)  Never gets below 65° or over 90°.  Helpers start dragging, just because they think they can control the sawing rate.
  This old man don't play that game.  ::) ::)  I put Reina on 'em, and she gets the gravy runnin.  It's an insult for a little woman to out work these strong young guys.  8) 8) 8) ;D ;D ;D
  When y'all get too cold, just drop on down. I always have some sawin to do, and NO snow ???  8) 8)
Brucer
Spring is nice, but I don't get many orders then.
Summer is too DanG hot, but that's when the orders start coming in.'
Fall is crazy. As soon as the kids are back in school, people suddenly remember that project they meant to do. I'll be going flat out, with a 4 week backlog.
Winter's a pain. Heavy, wet snow sticks to the bed rails and has to be scraped off each time you turn a cant. And Tom, when a frozen snow-covered log comes off the loader onto those stainless rails, that's when things get real exciting. Having to spend an hour digging out the mill for every hour of sawing isn't a picnic, either.
Bruce    LT40HDG28 bandsaw
T Red
Quote from: Brucer on October 10, 2009, 01:42:09 AM
Just wondering what temperature too DanG hot is in BC?
Tim
Papa1stuff
Brucer
Quote from: T Red on October 10, 2009, 10:24:35 AM
Over 30 degrees is too DanG hot. It never gets that hot unless the sun is beating down on you.
(Oh, yeah -- that'll be 86 degrees in 'American' ;D)
Fil-Dill
When sawing for furniture lumber, is it any different for drying, whether there is sap flowing or more dormant for winter.
EZ boardwalk 40
tyb525
I've *heard* it's better to fell trees and saw logs in the winter when the sap is down, not exactly sure why, I suppose it's because of the lower sap level.
Someone will have to confirm or debunk that ;D
Sap up and sap down is a myth.  The moisture content of the wood in a tree is generally constant throughout the year.  If the sap is up, the tree is alive.  If the sap is down, the tree is dead  :).
