Digger Logs??
Started by Jeff, December 04, 2001, 06:29:38 AM
Any ideas on this one guys?
 On 2001-12-03 at 08:33:49,
 The following information was submitted:
 From Host: **************
 name = Sharon K.
 submit_by = **********@yahoo.com
Geographic_Location =
 ask_the_forester_question = I am in school and need to know "What are
digger logs? "
timberbeast
I don't think this is what she is asking for,  but since I don't have hydraulics on my tractor,  and I skid my logs flat on the ground,  maybe I pull "digger logs".  My skid trails look like trenches with tire tracks on each side!
Where the heck is my axe???
Kevin
A digger log is a log that is placed at a 30o angle to the bank.  It is held in place with the use of rebar that, like the cover logs, is driven into the stream bed.
A digger log creates a miniature waterfall which scours the streambottom and over time creates a pool.  The stream gradually restores a natural pattern of flow that increases the suspension of sand to silt-sized sediment.  This in turn provides a well aerated gravel bed which is ideal spawning habitat for Salmon and Brook Trout.
bin milling
Frank_Pender
  Thank you, Kevin, for the new term as well as the definition.   I  reckon working in and around the woods all of ones life, one still finds the learning curve rising.  I will use the term at my next watershed council meeting and watch faces to see if anyone knows the term.  About fifty percent of the people are logger heads too.  It will be interesting.  Thank you. 8)
O.K. Kevin, fess up, where did ya find the answer??  :D
swampwhiteoak
My guess would be that Kevin values the good ole search engine.  Digger log:
http://www.acapcb.ns.ca/diggerlog.html
http://www3.pei.aibn.com/~sea/valleypic.html
But his quote comes from the bottom of this website
http://www.valleyweb.com/focs/projects.htm
Nothing wrong with letting google do the work for ya! ;)
Kevin
Ron Scott
Good job Kevin. I should have been thinking watersheds and fish habitat instead of timber. Forgot that one.
~Ron
L. Wakefield
   So from the pic it goes right across the stream bed but not perpendicular to the direction of flow- that's the 30* angle, right, that one end is further upstream than t'other? The only type I'd seen illustrated previously in a book on encouraging trout was a way to fake an undercut bank by making a wooden structure there as well- but it was like a little shelf built out from the bank, not something straddling the entire watercourse. hmm.. :)  lw
north_bugtussel
 ;D Kevin has the right idea. Can't remember everything you ever learned, or your head would explode! Trick is, remembering what book the answer is in. :P
Life is full of changes..the secret to life...is to out-live the situation at hand. VB
