Cutting beautiful Fir on our Peterson
Started by BandsawWarrior, July 25, 2010, 06:19:39 PM
I have plenty of knots if you run out and need a few  :).
Meadows Miller
Gday
Quote from: customsawyer on August 03, 2010, 04:34:22 AM
Just checking to see if you got those knots put in that wood yet.
Quote from: WDH on August 03, 2010, 09:03:13 AM
:D :D :D :D :D
You Reckon We should send Ty up afew Bags Fellas  ???  :D :D :D ;) but then theres the issue of instalation ill get Tim/banjo onta that one too I wonder how things are going his log n lumber stretcher  ??? ;) :D :D ;D ;D
Regards Chris
4TH Generation Timbergetter
terrifictimbersllc
Quote from: BandsawWarrior on August 03, 2010, 01:19:13 AM
Terrifictim we have the 10" ASM 3 phase electric...it works great for us.  We don't have the slabber option but we just use a 3120 and a 5' Alaskan sawmill.
We get a mixture of some good logs with a lot of bad logs lol...
Your slabbing choice is that just due to infrequent need for slabs or pretty easy to cut softwood with the alaskan or what? thanks.
BandsawWarrior
We don't cut slabs that often so Alaskan works just fine for us.  It's usually around 7min to slab a 12' long piece around 30" wide.  Can't complain about that.  If you were cutting a whole log into slabs it might be a bit much.  We just take one or two then start sawing boards again.
Tyler
Tyler Hart
T&N Custom Sawmill
terrifictimbersllc
B-W do you cut any hardwoods on the peterson 10" and how does that compare to cutting fir? more passes, slower, don't cut as wide etc would like to hear anything you can say about it.
