bandsaw questions.
Started by weisyboy, September 06, 2010, 06:24:14 AM
weisyboy
i am thinking of making up a band saw frame to fit the Lucas. or my lucas fixed site frame that i am making.
i have a few questions.
1. why dont you guys run wider bands. all the resaw band saws in aus run 4" plus wide bands and even on my shop saw i run a 1 1/2" 1tpi band of resawing. it seams most of you run blades about 1 1/4" blades or am i getting it wrong?
2. are car/truck rims/wheels god enough for band saw wheels. that is, balanced well enough, round enough and all round suitable.
3. anything that i need to watch out for?
god bless america god save the queen god defend new zealand and thank christ for Australia
www.weisssawmilling.com.au
http://www.youtube.com/user/weisyboy?feature=mhee
http://www.facebook.com/profile.php?id=100000696669814&sk=photos
ladylake
1    1-1/4 bands cut good and are reasonable to run
2    Turner runs them on thier mills and quite a few home built
3    Make a heavy frame, band saws take a lot of abuse with big logs.   Steve
bandmiller2
Weisy,most bandmills run 1 1/2 or1 1/4" bands because their reasonably priced and do the job.Wider bands would require a much heavier frame to tension them,then your treading in commercial waters.Some shop saw like the Makitas use a wide band but they are thin and flexable.Bandmills can be built using tires and rims in fact they work quite well,if I were going to use them I'd use the hard donut type spares the cars come with now.I think you'd be better off with two seperate mills your swinger and a bandmill they augment each outher rather than trying to combine them.Good luck mate Frank C.
weisyboy
think is i need something that is gunna perform on a commercial basis. im not just doing this for a hobby.
we have built many bench saws and the like. but never attempted a band saw.
wouldnt a wider band reduce wander?
ill make is solid alright. its not gunna be portable so weight doesn't matter. i like to make things over the top. it can never be to strong.
Kansas
Up to two inches wide, you can still just sharpen and set them. Over 2 inches, you have to have all sorts of specialized knowledge and equipment for hammering them, etc. At least that was what I was told over the years.
Chuck White
I have a Cook's Cat Claw sharpener and I can sharpen "up to 4 inch" bands with it, but I have no desire to go larger than the current 1ΒΌ inch bands that I've used from day one.
I don't think that band width would make a lot of difference in sawing, provided that you are running the appropriate tension and the band are sharp!
sgschwend
Many mills have 19" diameter wheels, that limits the band to about 1 1/2 inches.  A 2" band would likely be a good choice without causing to many changes, larger wheels would be needed and larger tension cylinder.
Portable in the US means the mill must have a total width under 102".  Larger wheels become difficult to fit inside the 102" width.  There are several mills with 24 and 26" wheels that do fit, however the maximum cut width is likely less that a 19" wheel mill.
I would not use car/truck rims, there are wheels that you can find, both steel rims or compliant material.  Mighty Mite uses compliant material bonded to the steel wheel and then they machine a crown in the wheel.  I think it Cook's that sells a 26" steel rim (might be a 24").
Steve Gschwend
sjgschwend@gmail.com
bandmiller2
Weisy,do you fellas down under have any of those old make and break one cylinder engines,they have dandy big cast iron spoked  flywheels.A good sharp 1 1/2, well set band, will cut well  and is economical to buy and sharpen.Two  inch is good but not too common and more expensive,sometimes the gain of going large is not worth the cost.Frank C.
fishpharmer
Weiss, this bandmill uses 29" diameter trailer wheel/tires running a 1 1/4" band that is 21.5 feet long.
It was not made for production , yet cuts very well.  The throat is 48 inches wide and high.  An amateur built it.  Nothing wrong with tires. There is an unbelievable amount of variability in how true new off the shelf wheels turn.  It took several attempts to find two true running wheels.
To add insult to injury, here is a too long video of the mill in action.
http://www.youtube.com/watch?v=n8NqF0qbljE
There are more in my gallery if your interested, I think I posted these pics before, hope they are relevant to your thread.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Okrafarmer
Quote from: fishpharmer on September 06, 2010, 09:44:54 PM
That your mill, Fish? Looks like you get your workout stepping over those hurdles all day!
The pneumatic tire setup is used on the Turner mill, which my boss has, and evidently it works quite well-- supposedly increases blade life compared to metal drive wheels. The Turner is not full professional strength, but Fish's saw looks more like it.
Will it go any faster than that, Fish, or is it limited to the speed of the operator's leg muscles?  :)
Now selling Logrite tools!
fishpharmer
Okra, yessir that be mine. It is indeed a workout, automation is in order.  The other mill is a recent addition.
The Turner's are nice mills.  The tires are unconventional bandwheels yet vey effective.  I don't think anyone should avoid using them for a mill.
Speed is limited by operators legs.  Also, horsepower can be a limiting factor in speed of cut.  Here is a link to an early post giving details of mill https://forestryforum.com/board/index.php/topic,34917.msg505666.html#msg505666
Carl, hope this helps you.  Search homemade mills, there are many on here.
bandmiller2
Fish,you really have that band running stable, do you have a moveable guide to limit the unsupported band?? What seems to limit your feed speed single drive belt or engine HP.Good build and good capacity but don't stop now its just crying for automated feed. Frank C.
fishpharmer
Thanks BM2, yes the right side (as you look at it in video) is a moveable guide, realize now i should have moved it.  I  upgraded to double belt pulleys (no slippage) at Tom's recommendation. Speed limited by leg power more than horsepower.  Improvements are in order once it finds a permanent home under a shed.
Weissboy, are you looking at powerfeed or manual for your build?
weisyboy
probably powered feed.
is that as fast as they normally cut?
my slabber cuts 4x faster than that.
im not gunna muck around with little motors. nothing worse than an underpowered saw. some of the benches im used have had 200hp running a 25" cut. obviously im not gunna go that far but im not gunna put 8hp on it either.
i was thinking like a 25hp diesel motor.
fishpharmer
Weisboy, my mill would be considered slow for a band mill.
Here is a faster example of a bandmill.
http://www.youtube.com/watch?v=bmdMo09tJpQ
bandmiller2
Weisy,what I did that works well building a bandmill.Four post design,use square thick wall tube,run on "V" castor wheels the bigger the better.Run all functions with hydraulics,to feed use a hyd. motor with a drum and wire cable.To raise and lower the bandhead and engine I used a hydraulic cylinder and wire cables reeved to give two to one travel,one inch cyl.travel= two inch band movement.Thats the system used by most arial ladder trucks its very controlable and can lift heavy engines.
