JRED 670
Started by Keltic, January 12, 2004, 02:43:31 PM
Keltic
Hi, was offered a rebuilt 670, interested in experiences/ opinions of this saw. Thanks FMK
Corley5
If you get one pinched in a cut don't pull to hard or you'll break the rubber mount between the intake and the carb.  That's the only experience I've ever had with one but it ran well and cut good until I got it pinched.  The guy I was working for took it back to the dealer and I never saw it again.
Oregon_Rob
This is from acers site:
MANUFACTURED BY:  JONSEREDS FABRIKERS AB
  PARTILLE, SWEDEN
SERIES OR ASSEMBLY NUMBER:
YEAR INTRODUCED:  1986
YEAR DISCONTINUED:  1997
ENGINE DISPLACEMENT:  66.8cc (4.1 cu. in.)
NUMBER OF CYLINDERS:  1
CYLINDER BORE:  50mm (1.97 in.)
PISTON STROKE:  34mm (1.34 in.)
CYLINDER TYPE:  Aluminum with chrome plated bore
INTAKE METHOD:  Piston ported
MANUFACTURER ADVERTISED H.P.:  3.3 kW @ 9,600 rpm
WEIGHT :  6.13 kg (13.5 lbs.)
OPERATOR CONFIGURATION:  One Man operation
HANDLEBAR SYSTEM:  Anti-vibration
CHAIN BRAKE:  Inertia activated
CLUTCH:  Centrifugal
DRIVE TYPE:  Directg
CONSTRUCTION:  Die cast magnesium
MAGNETO TYPE:  Electronic
CARBURETOR:  Tillotson HS series
MAJOR REPAIR KIT:
MINOR REPAIR KIT:
AIR FILTER SYSTEM:  Nylon mesh cartridge
STARTER TYPE:  Automatic rewind
OIL PUMP:  Automatic, gear driven
OPERATING RPM:  9,600
IGNITION TIMING:  fixed
BREAKER POINT SETTING:  none
FLYWHEEL/COIL AIR GAP:  0.30 to 0.40 mm (0.012 to 0.016 in.)
SPARK PLUG TYPE:  Bosch WS7F, Champion RCJ7Y
SPARK PLUG GAP:  0.51 mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS:  Ball
FUEL TANK CAPACITY:  730 ml (24.7 oz.)
FUEL OIL RATIO:  40:1
RECOMMENDED FUEL OCTANE:  Regular
MIX OIL SPECIFICATION:  Electrolux approved two-cycle mix oil
CHAIN PITCH:  3/8 in.
CHAIN TYPE:
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED:  33 cm (13 in.)
LONGEST GUIDE BAR SUPPLIED:  71 cm (28 in.)
COLOUR SCHEME:  Red and Black
PAINT CODES:
Generaly know to be a good saw
Chainsaw Nerd
oldsaw-addict
I have one of these 670s myself, I LOVE it, just gotta get it to run soon. But it is basically a Husky 266 with Jonsered decals on it. They are lighter than my McCulloch PM610 which is a 3.7 CID and weighs about 20 LBS or so, while the 670 is 13.6LBS and very nice. I cant complain about their style. But in short the 670 is a VERY GOOD saw.
Let there be saws for all mankind!
Bobcat_pa
Oregon_Rob:   what is the full "www" for the acers site ?    Is this some type of tech info center ?    bob
oldsaw-addict
the web address for the acres site is www.acresinternet.com  then click on the chainsaws link. I use the website for information on many things relating to my saws on all repairs. very useful information.
Keltic
Thanks for the replies, very helpful !!
