Found something odd on my LT35 today,
Started by 123maxbars, December 26, 2011, 07:50:53 PM
customsawyer
I have had 3 mills with the metal bolts and can't remember a single time that it has messed up a blade.
www.thecustomsawyer.com
pineywoods
If there is 1/16 inch clearance and the band is rubbing the block/bolt, I'd be looking for the reason. It will be a mechanical resonance situation, and that's something thats not easy to comprehend. Slightly changing the drive belt tension or engine rpm just a tad might stop the flutter. Blade tension will also have an effect. Too much hook angle in real hard woods can also cause blade flutter.
ely
Tom, told me along time ago in a pm about that bolt, it started out as a bearing on a bolt. he said it was up there in case the band got to moving up and down too much it was to keep it all in check.
Tom went on to say he had seen the bearing replaced with all varieties of wood and a few plastic and other soft materials. In Toms' words "you can put anything you like up there, chances are it will never touch the bands anyway."
My mill still has the bearing up there (87 lt30 )  It's seized up. Does not turn. It was that way when I got the mill. Tom also said not to worry about it, it didn't need to turn.
millwright
I also have an LT35 and have seen the wooden block, but it doesnt appear that it has made any contact that is visible after sawing about 15,000 bd ft.
123maxbars
After alot of research and talking with my woodmizer Rep it looks like the wood block was the right side, but came loose from the two screws and was lower that it was suppose to be causing it to rub against my blade.  Thanks for the help on here!!
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Chuck White
Glad to hear that you have the problem taken care of 123maxbars.
musikwerke
My 1987 LT30 has the roller bearing on the stud.  I replaced it and set the clearance when I rebuilt the mill.  It stays clean and rust free on the circumference so something touches it once in a while.
John
It may be that its simply getting scoured with sawdust. The outer part of mine gets clean looking to when I saw, but nothing ever touches it that I know of.
