Timberking / Talon Sharpener and Dual Tooth Setter
Started by vfauto, January 03, 2012, 03:19:29 PM
tommone
Thanks for reply and explanation Tim. Interesting that the Talon can do the whole profile without the aid of a cam. tom
coastlogger
Must be a cam there somewhere. Id guess its under the depth adjustment rod. Looks like a nice sharpener for the money.
clgr
ladylake
 Looks like the cam is under the push rod pivot bolt.    Steve
TimGA
Hey guys, there is a cam mounts directly on motor, it makes everything go up and down and back an forth. Adjustments up,down and so forth make it possible to make complete profile.              NOTE !! This is last paragraph from operaters manual.                      Most saw sharpeners only permit a pre-determined gullet shape and use changeable cams for different shapes. This limits the users ability to change the  hook angle and/or gullet shape without purchasing a different cam. The Timberking Sharpener's unique timing adjustments allow the operater to change the hook angle while maintaining the correct gullet shape or change the gullet shape and/or depth, as well as being able to grind the tooth face while "topping" the next tooth without grinding the gullet deeper. Combining the three timing adjustments permits a wide variety of tooth profiles to be made. The user should become familar with each of these adjustments and the affect they have in creating the desired tooth and gullet shape.           Hope this clears this up.  Going to apply for a job as sharpener salesmen. Ha Ha no way don't know enough.   Good night   Tim
TK2000, Kubota L3130GST, grapple, pallet forks, 2640 Massey w/loader (The Beast) Husky saws Logrites One man operation some portable most stationary.
redbeard
Thanks Tim simple is one thing I understand. Sounds like your getting some good results. I have my eye on it. I will mention you on my order.
ladylake
 Now that things are cleared up it sounds like a excellent sharpener at a great price..     Steve
bandmiller2
Thanks,thats the information needed.A little tip get a diamond wheel dresser much more effective dressing wheels than the cheap abrasive brick usally supplied with machines.I prefer the diamond grit dresser as opposed to the single diamond point. Frank C.
vfauto
Quote from: xlogger on January 06, 2012, 06:21:11 AM
I grinded my first blade last night on my TK (Wright) grinder. Now to see if I know what I was doing :-\. I'll try it this weekend after I dull the one I have now off. Ricky
Hi xlogger, we never heard back from you on how the sharpner and setter worked out. Just looking for some feedback before I buy somthing.
The definition of insanity is to do the same things over and over and expect a different result!
