skidder tires
Started by MICKEY108, February 13, 2012, 08:57:59 AM
MICKEY108
I HAVE A 240A TIMBERJACK WITH 23.1X26 TIRES I WAS WONDERING IF 18.4X26 OR 18.4X34 TIRES WOULD GO BETTER I LIVE IN SW VA REAL STEEP MOUNTAINS
lumberjack48
18.4x34 to high and narrow
18.4x26 , 18.4" wide, 26.2 loaded radius, with this tire you get more weight per sq.. inch on the ground and its 2.4" lower then the 23.1x26 tire. besides about $800. cheaper in a 10ply Forestry Special. By far my choice , then load-en up, that Timberjack would be like a mountain goat
23.1x26,  23.1" wide, 28.6 loaded radius , there only 4.7"s wider and 2.4"s higher then the 18.4x26, cost wise i go back to the 18.4x26 tire.
Third generation logger, owner operator, 30 yrs felling experience with pole skidder. I got my neck broke back in 89, left me a quad. The wife kept the job going up to 96.
timbuck2
18.4 x 34's were the preferred size around here,   bigger tire rolls over obstacles better, more clearance, and cuts thru snow to get traction.,   Mostly rough ground here, frozen up tight during winter.   Never had loaded tires but some guys would load the rears and liked it.  Steep ground, GO for it, just don't turn around on a tree and stave up your fuel tank.
Ed_K
Mine has 18.4-34s  I recently had the rears loaded with rim-guard.What a difference.This was after going down a hill and wondering why the blade was going into the ground and looking back to see back tires 4' off the ground  :o .
Ed K
smwwoody
I have spent many hours in a 240 with 23.1 - 26 and 18.4 - 34.  my pick is the 18.4 - 34   the 18.4 - 26 are too small for a 240
WOODY
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
MICKEY108
thanks 4 all the help mickey108
lumberjack48
18.4--34 on a S8 or a C5  put the center of gravity to high.
Heres a quick chart to check difference in width and Height.
http://store.skiddertires.org/Firestone-Forestry-Special.html
Bobus2003
I run 18.4 -26's on my JD440, All four are loaded (75 gallons per tire).. Keeps her planted to the ground pretty good.. unless ya get stupid
lumberjack48
I had all four loaded on my S8 with 18.4 - 26's with a power shift. This is the only set up if your going to be running on steep ground. My C5-D had 18.4 - 34's with out fluid, and stick shift. This set up on steep ground is a accident waiting to happen.
The C5 with 18.4 - 34 tires is so rough riding, really a head banger. A person has to be care full, you could tip it over on flat ground. A C5 with 18.4 - 26's or 16.9--30's , rides better, you don't have to hang on for your life. When you load the tires, it will ride like a Cadillac and pull like a mule.
The thing is when you load your tires you don't need chains. You don't see a farm tractor with out fluid, with out fluid they wouldn't pull their own weight.
5akman
What are the tires loaded with, just water? How about foam filled like they do with junk yard skid steers to prevent puncturing a tire? Perhaps that'd be a horribly rough ride with hard tires....
1978 JD 440C
lumberjack48
Bobus2003
Quote from: 5akman on February 15, 2012, 01:30:29 PM
Sodium Chloride (Salt) and Water is what I use, Never freezes, but if you spring a leak it will rust the rim in a hurry, and it has been known to cause the tube to stick to the rim and cause flats also. Foam filled tires would be a good idea for puncture proof, but doesn't add much weight at all
Salt is what is what I use for weight in my tractor tires too. Does cause some rust,but leaks have to be taken care off and cleaned up real good each time.Really makes a big difference with a tractor. Even our 30 hp lawn mower are loaded too.
