New project, we'll see how it unfolds.
Started by SwampDonkey, November 20, 2011, 04:32:53 PM
Been working on this raddle. The spacing of 1/4" dowels 4" long is 1/2" on centre. I think there are 150 dowels, after 80 I stopped counting and i was half way across. Just began those when it was quitting time. ;D
The raddle is used to spread the warp threads evenly across the width of the warp roller as it's wound on. Bouts of warp threads are layed between the dowel pegs, probably 4 threads of 2-ply wool would fit. This helps keep count of the warp threads. The top section is meant to come off while doing this. Then it is placed on and there is a 5/16" wide by 1/2" deep slit in it that fits over the dowels. There will be a peg hole drilled in the ends of the raddle top and through the uprights. The top of the uprights has another hole and is to be rounded on the top end. I believe this is used to suspend the raddle from the loom frame overhead if desired. Also, a stand will be made which can be bolted to the back of the loom onto the warp beam.
This is what I got done today.
Burlkraft
Wow Donk this is an extra- large project and you are doin' a fine job  8)
We gotta see and hear about this gal pretty soon. She must be very special  ;)
Why not just 1 pain free day?
That is some fine work for sure, so she must be something very special indeed.  I think that Marcell was on to him early on, but he has been very quiet about this  :).
Lud
SD, how many harnesses are you planning to have?  Very Glimakra-esque......
I understand the dowels on the rattle as an option but don't you want it to hold a regular reed as well?
Nice work all the way...... 8)
Yup, I'm going to make a 4 dent reed for starts. I have not yet decided on the number of harnesses, but am making provisions for 8 treadles. I'm thinking 8 vertical jacks so at least 8 harnesses. A vertical countermarche only requires one harness per jack. I've got to make 1200 heddles from Texsolv for 20 ends per inch across 60" of weaving. :D
I've got to make a temple as well right off soon.
Holmes
Think like a farmer.
I put this temple together today from hard maple, it extends to 65 inches. Made a 1/8" brass pin with an eye for a handle, made a SS sliding band from a band clamp and I used finish nails inserted at 30 degrees on the stretchers. I drilled all the way up the length of the outside piece as it was easiest to line up the holes in the insert (middle piece). This is not needed and the plans do not call for it. The outside piece just needs on hole drilled through and through as the falcrum on the end. Anyhow, doesn't detract from the piece in my opinion.
The temple is used to keep the weaved fabric from pulling in caused from too much tension in the weft threads.
Enjoy :)
Burlkraft
This is all beyond me now...I forgot where we started and are we ever gonna get done makin' stuff??
Spring is on it's way young man!!  :-* :-*
 :D I don't think making stuff ever ends when your talking about weaving. One thing after another I'm thinking. ;)
Still about 2-1/2 months of winter yet. Don't rush time along too quick, enjoy life. ;D
Pirn winder.  That blue band is an elastic band off broccoli bunches. ;D
A little video to follow. ;)
Clark
From what I hear you better be quick Donk!  Get ripping those floorboards up because I'm certain you've kittens or puppies under there that are dieing!
Clark
SAF Certified Forester
 :D :D Might be having kittens before it's over with. :D
Warbird
Mooseherder
In certain circles the women will be fighting over you. ;D
Think I should join the Madawaska weavers? :D :D
Mooseherder
If you have the time.  SURE, Why not!
I wouldn't think any less of you, especially if that's where the women are. :D
That device talks to you while you work!  Good show.
I needed a small peg hammer to tap the pegs in and out of the loom when moving (which I don't plan on doing once it's complete :) ) Went to the scrap pile and picked out some pieces. The hammer is held in the head with a wedge that tightens as you knock the handle onto the head. Notice not drilled all the way through. ;D
Burlkraft
Looks good Donk.....All I can say is bees' wax could be your friend!  ;D
I've got wax, but a lot of the squeak is the 1/8" brass rod used on the reel from friction. I plan on putting some on the winder though. I have to turn a different handle on the big wheel because it was off centre a little. Doesn't affect the winding other than you here a snap once in awhile because of the slop in it where I drilled it again to aline the hole. No biggy, going to do that after dinner.
Patty
Very cool Donk! I am impressed.....especially after I muted the sound.  ;) :)
Women are Angels.
And when someone breaks our wings....
We simply continue to fly ........
on a broomstick.....
We are flexible like that.
