Strainer and fuel filter for TJ450A
Started by jd540b, March 13, 2012, 05:34:36 PM
jd540b
Hey, Does anybody know what NAPA/ WIX/ Car Quest, etc. filter numbers cross reference from Timberjack filter part #'s 8411228 (strainer) and 8411230 (filter)?  Want to switch from cannister elements to spin-on's.  Thanks all.
bushmechanic
Not sure about Napa numbers but here are Baldwin numbers 8411228-BF592,8411230-BF593.Also here are Donaldson numbers if those are better 8411228-P550936,8411230-P550928.Those are part numbers for Detroit diesel fuel filters if that is what is in your TJ450A.
jd540b
Bushmechanic-Thanks, that helps alot.  Yes, it has a 4-53.  Thanks again!
doghunter
 i just converted my 230d to spin ons i bought new bases from the baldwin dealer they bolt right in place and use the origional lines all i needed was a couple of 1/4-3/8 pipe bushings. i also put on an adaptor kit to convert the oil filter. pm me if they are not available in your area and i will send you the number of my baldwin dealer and he can ship them to you.
deerguy
Hey fella's the timing for this conversation is perfect. I have my old TJ tore down, and getting it converted to spin-on's would be a perfect addition while its apart !!!! I noticed the discussion centered around a 4-53, does anyone have any info on a 3-53 or would it be the same parts ????? Any info most welcome.....
I knew she was a keeper when she told me to buy the old skidder !!!!!
bushmechanic
Yes deerguy the fuel filters are the same,that's how I knew the numbers they are the same ones for our TJ230D forwarders with 353's in them.Not sure if the oil filter would be the same.
doghunter
ok here we go;baldwin filter part numbers
primary fuel filter base#fb-1302 filter#bf-593
secondary fuelbase#fb-1302 filter#bf-592
oil filter adaptor to spin on base#ob-1303 filter#b105 short filter #b95 long filter
