10-30 blades
Started by Nomad, November 13, 2012, 11:41:13 AM
Nomad
     Anybody got a print of the blade for a 10-30?  I'm going to try a different saw doctor, and the blade I showed him is the first swing blade he's ever seen.  He's asking for a drawing to make sure he's using the right bits, grind, radius, etc.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
logboy
Can you just order the teeth from Baileys and give them to him? I did that so my local guy could match. Otherwise you might have luck just contacting Lucas for the specifics, or bring in a new blade for them to examine.
I like Lucas Mills and big wood.  www.logboy.com
Nomad
Quote from: logboy on November 21, 2012, 01:54:31 PM
     He swears he can supply the carbides, regardless of what size they are.  Sigidi gave me the diameter of the blade (so he can get the proper tip radius) and all the pertinent sharpening angles, so I think I'll be okay.  But as you say, if all else fails I've still got a new blade I could bring him.  In fact I may just do that anyway.  That way when I pick up the first blade we can compare apples to apples together.
Lucas DSM23-19
logboy
QuoteBut as you say, if all else fails I've still got a new blade I could bring him.  In fact I may just do that anyway.  That way when I pick up the first blade we can compare apples to apples together.
I brought a factory blade in, and I'm glad that I did.  My local saw doctor was jumping up and down trying to tell me that it was incorrect the way Lucas makes their blades (despite him never seeing one in action, or ever hearing of a swing blade mill). I told him what he thinks about how Lucas makes their blades is irrelevant,  if he can't do it the way I want I will take it somewhere else.
QuoteI will take it somewhere else
And hopefully that is what you are going to do. ;)
Nomad
Quote from: logboy on November 27, 2012, 12:38:35 AM
     Yup.  This company has been in business forever and they're supposed to be as good as they get, but he's having a hard time understanding why the radius is so important 'cuz he's never seen a swingblade mill before.  I've got some tips on order; should be here in a couple of days.  Then we'll see if he can match them or not.  And I'll bring him a brandy new blade to compare measurements and angles.  In a past life I was a machinist.  If his apples don't match my apples, I won't have any problem 'splaining the discrepancies.
Lucas DSM23-19
