woodbug
Started by garre1tt, July 04, 2006, 03:34:12 PM
garre1tt
Does anyone know what happened the the Woodbug web site?
Did I put off buying this mill for two long?
Any help would be great.
Michael D.
Woodmizer LT 40, 1900 Linn Lumber Band mill, massey ferguson 245 tractor, Stihl 084,066,036,370,290,018
Past owner of WoodBug CSM, Alaskan CSM,1900 Linn Lumber Band mill, Lucus 6-18 Stihl 064, Stihl 084
jpgreen
They may be gone Michael, and belly up.  Too bad to because it's an awesome mill, for the owner operator.  I've cut a lot of accurate lumber on one.
I tried contacting them several times and no response. Big problem was probably shipping costs killing their business for one reason.
I can make you one if you want to come and pick it up... ;D
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Dan_Shade
Did you ever get around to finding that filing method in the manual?
All I've ever heard is how great the woodbug method is...
lots of dull bands and chains
Mr Mom
     Just did a search and found the site at woodbug.com
     Thanks Alot Mr Mom
garre1tt
Well I was afraid I would wait to long.
Shipping was one of the reasons I waited, Then steel prices, exchange rate and so on.
JP I will keep your offer to build one open.  I don't really need it for a couple of more years.
Although now that I am stationed on the central coast of California you are the closest I will be to you.
Michael D.
jpgreen
Sorry about that Dan... I totally forgot about it, I've been so busy.
Angles they (woodbug) filed are 15 degrees point high (chain cutter corner, called point) and 25 degrees across the tooth. Starting with a 7/32" file on a oregon "R" type 73 RD, or 73 RA ripping chain. These are 3/8 x .058 chains.
THey used an Oregon file guide (Oregon part No. 23736A) and took it apart and reversed it to file from the outside of the tooth in, at those angles.
jpgreen
Quote from: Mr Mom on July 04, 2006, 07:54:23 PM
     Thanks Alot Mr Mom
I get a closed underconstruction notice at that address...  ???
It worked for me.
Try this link:
WoodBug
jpgreen
Sho Nuff... leave the 3-dub'ya out..  8)
garre1tt
Thanks for the help
Michael D.
MotorSeven
Michael,
The one i bought was damaged by a tree during Katrina(tree revenge?). So i priced out the steel to fix the one section($40), then i priced out the steel to build one 23' long from scratch-approx $250. It is only 1/8 inch angle and square tubing. I plan on building this soon, and it will allow me to cut beams out to 40'.
RD
WoodMizer LT15 27' bed
