De-barker
Started by Gentlewolf, December 01, 2013, 10:36:08 PM
Gasawyer
I agree that red clay is problem almost as bad as sand. I would do without set works before not having a debarker. Really depends on where you're logs are coming from on how necessary a debarker is. Most of the time I need it.
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
I had seven logs really caked with dried mud today.  I got 1500bf, but it took 4 blades.  The Debarker took care of it's side and we wire brushed as best we could with the off side, but it was still bad.  They looked like glazed donuts.
POSTON WIDEHEAD
Quote from: Magicman on December 03, 2013, 08:50:51 PM
Just be glad you had a Debarker with all that mess!  :D
Peter Drouin
Mud, you should try frozen gravel and rocks on a log and the de-barker rides over the rock and cleans it nice then the blade cuts the rock in half and ruins  the blade.  :D :D ;D
A&P saw Mill LLC.
License NH softwood grader.
I can not even imagine the horror of frozen mud or logs.   :o
Peter Drouin
Even the bark freezes on the log. Can't get it off either. :D :D
A&P saw Mill LLC.
Brucer
The one case where I'd like a debarker on the exit side of the cut is when I'm sawing an ice-covered log in the winter. More than once I've seen the sparks flying on the exit -- the blades is sawing through dirt that's embedded in the ice :(.
Bruce    LT40HDG28 bandsaw
kelLOGg
OK. It's time for someone to say "it always comes down to food". I did it.
Speaking of food, the NC gathering will be Saturday IF it isn't rained out.
Bob
JFarmer
Buy the debarker. It will save you time and money and you wont regret it!
LT40 electric,woodmizer twin blade edger,cooks catclaw sharpener,suffolk setter, john deere 450 dozer, case 90xt skidsteer, 7010 4x4 mahindra tractor
backwoods sawyer
I use the mud saw only when logs are dirty, and have worn out the motor and both arms, ordered a complete new set up from wm.
Over the last couple months while the arms are being build, we have been sawing logs like mm pine, avoid the mud to some degree, never the less a box of saws don't got as far.
Backwoods Custom Milling Inc.
