redissolve anchor seal?
Started by Brad_bb, June 01, 2014, 06:56:43 PM
Brad_bb
Recently started using it, and I have a cut with a cut lid for my brush.  Some of the left over started drying in the cup.  Can I redissolve it?  Will just water do it?  Alcohol?
Brad the thing I would do is take a small amount and try mixing it with water. You should soon know if that's the fix if not try the alkie. Frank C.
POSTON WIDEHEAD
Anchor Seal starts turning to wax pretty quick. I would think you would have to heat it.
Some guys use Anchor Seal to tumble lube cast bullets, its kinda like commercial floor wax. Frank C.
It is water soluable.  Very hot water would do the trick, I suspect.
POSTON WIDEHEAD
Left Coast Chris
I have Baileys end seal and it started thickening up.  Just added cold (sorry Poston) water, put the cap back on the 5 gal bucket and mixed well by shaking/sloshing.   It is a waxy emulsion I assume similar to Anchor Seal.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Well that throws cold water on the hot water theory  :D.
POSTON WIDEHEAD
Quote from: Left Coast Chris on June 02, 2014, 10:10:46 PM
Glad it work......I had no idea, I was just guessing a solution.  :) I started using Anchor Seal last year after learning about it on the FF. It has saved my crack lots of times.  ;D
Brad_bb
Thanks!  I'll try ...one of those.
Quote from: POSTONLT40HD on June 02, 2014, 10:16:24 PMIt has saved my crack lots of times.  ;D
There are other ways of saving your crack.  Crack Spackle
