Author Topic: redissolve anchor seal?  (Read 1100 times)
Offline Brad_bb
« on: June 01, 2014, 06:56:43 PM »
Recently started using it, and I have a cut with a cut lid for my brush.  Some of the left over started drying in the cup.  Can I redissolve it?  Will just water do it?  Alcohol?
Offline bandmiller2
Re: redissolve anchor seal?
« Reply #1 on: June 01, 2014, 08:25:04 PM »
Brad the thing I would do is take a small amount and try mixing it with water. You should soon know if that's the fix if not try the alkie. Frank C.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: June 01, 2014, 08:34:31 PM »
Anchor Seal starts turning to wax pretty quick. I would think you would have to heat it.
Offline bandmiller2
« Reply #3 on: June 02, 2014, 09:37:24 PM »
Some guys use Anchor Seal to tumble lube cast bullets, its kinda like commercial floor wax. Frank C.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: June 02, 2014, 09:49:23 PM »
It is water soluable.  Very hot water would do the trick, I suspect.
« Reply #5 on: June 02, 2014, 09:56:24 PM »
I would think you would have to HEAT it.
So I win by proxy.  ;D
Offline WDH
« Reply #6 on: June 02, 2014, 10:05:01 PM »
You got my vote!
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #7 on: June 02, 2014, 10:10:46 PM »
I have Baileys end seal and it started thickening up.  Just added cold (sorry Poston) water, put the cap back on the 5 gal bucket and mixed well by shaking/sloshing.   It is a waxy emulsion I assume similar to Anchor Seal.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline WDH
« Reply #8 on: June 02, 2014, 10:15:07 PM »
Well that throws cold water on the hot water theory  :D
« Reply #9 on: June 02, 2014, 10:16:24 PM »
Glad it workI had no idea, I was just guessing a solution.  :) I started using Anchor Seal last year after learning about it on the FF. It has saved my crack lots of times.  ;D
Offline Brad_bb
« Reply #10 on: June 03, 2014, 02:05:03 AM »
Thanks!  I'll try ...one of those.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: June 03, 2014, 08:58:12 AM »
  There are other ways of saving your crack.  Crack Spackle
Anchor seal
Started by Bruno of NH on Sawmills and Milling
Last post September 27, 2016, 09:20:06 PM
by 4x4American
anchor seal sprayer
Started by Dan_Shade on Sawmills and Milling
Last post July 20, 2006, 01:14:38 PM
by rebocardo
anchor seal alternatives
Started by Alexis on Timber Framing/Log construction
Last post March 26, 2010, 01:49:24 AM
by bub4e
Anchor seal or paint
Started by DWM II on General Board
Last post May 25, 2007, 10:35:29 AM
by Ironwood
