We have contest winners!
I'd use a gearmotor with chain and sprockets.
There is an extensive thread on this subject.Bobhttp://forestryforum.com/board/index.php/topic,16775.0.html
Another question came to mind about head raise systems. I have not seen a system that is counterweighted. A counterweight would limit the force required to lift the head and thereby make a gear/chain system more effective. Or is there some reason this is not done.
Quote from: waynorthmountie on February 08, 2018, 09:56:42 PMAnother question came to mind about head raise systems. I have not seen a system that is counterweighted. A counterweight would limit the force required to lift the head and thereby make a gear/chain system more effective. Or is there some reason this is not done.And now it becomes painfully obvious. I would think if the head was floating that it would enhance wavy cuts.Best to let the gravity do its work and hold things down.
I did not know that. So it's like course and fine thread pitch?
Started by CCCLLC on Sawmills and Milling
Started by AnthonyW on Sawmills and Milling
Started by shortlogger on Sawmills and Milling
Started by GAmillworker on Sawmills and Milling
