Author Topic: Dozer winch for skidsteer?  (Read 1707 times)
Offline Pclem
« on: February 09, 2018, 08:16:15 AM »
I used to have a home built tractor winch that came off a dozer. Plugged into aux. Gpm's on tractor were slow. Worked ok. I assume I would get more performance with a bobcat with higher gpm? I'd like build my own and want to know what to look for. Not gonna be for pulling a big hitch, just hung up trees, and hard to get stuff till I can grab hold with the bobcat. I see they make new hydraulic winches for autos, assume they run off power steering? Would this be a viable route too?
Dyna SC16. powersplit. supersplitter. firewood kilns.bobcat T190. ford 4000 with forwarding trailer. a bunch of saws, and a question on my sanity for walking away from a steady paycheck
Offline mike_belben
  • Pulp Friction
Re: Dozer winch for skidsteer?
« Reply #1 on: February 09, 2018, 11:05:53 AM »
I use a $300 chinese 12vdc electric winch on a reciever hitch plate for use on aything i weld a reciever to.  Its got a short lead with an anderson connector for the things ive hardwired, and i made a long jumper for everything else.  All my trailers and a few of my attachments have receivers and everything obviously has one or more 12v batteries.  I use arc welding cables from the scrap yard to make up power wires.  The ring terminals are just pieces of soft copper tubing, hammer smashed and soldered on with a hole drilled in the tab.   Pretty much all my batteries are group 31 semi tractor batts with stud tops now.  No more lead clamp headaches.
Isaiah 63:10
Offline chevytaHOE5674
« Reply #2 on: February 09, 2018, 12:03:16 PM »
I had a mile marker hydraulic winch like you mentioned that was meant to run off a power steering pump and powered it off my dozers hydraulics and it worked good for pulling wood and what not. My only complaint was it was slow, would pull a house but takes all day to do it.
Offline Riwaka
« Reply #3 on: February 10, 2018, 12:52:43 AM »
A light/ medium hydraulic  wrecker truck winch. Probably find lower cost one if a wrecker has been in a wreck itself.
https://www.warn.com/industrial/winches/hydraulic_winches_all.jsp
(warn, mile marker - how many other brands ? most have good and not so good models)
20 feet of remote cable on some if you need a bit of stand back space.
Mounting position &machine positioning fairly important to give a good pull.
Should also see if there are any skid steer winch units around (clutch units etc)- used to compare cost wise/ time saving vs building your own.
Wrecker winch with plastic rope - fairleads and smart use of block
Asian friends appear to still have a bit of development work left to do on their model
eterra slow/ fast - clutch for pullout.
skidsteer winch
Started by h2ofwlr on Forestry and Logging
Last post January 28, 2021, 06:02:10 PM
by 230Dforme
Dozer Winch
Started by Fla._Deadheader on Wanted
Last post February 20, 2008, 12:03:08 PM
by Fla._Deadheader
TD7E DOZER WITH WINCH
Started by Jwinter7258 on For Sale
Last post January 06, 2019, 03:27:58 PM
by Jwinter7258
Case 350 dozer w/ winch
Started by shinnlinger on General Board
Last post February 08, 2012, 06:15:24 PM
by POSTON WIDEHEAD
