Author Topic: Solar lights for the barn  (Read 3182 times)
Offline LeeB
« on: March 25, 2018, 12:30:03 PM »
Lindy bought two Renoogy 100 watt 12 volt solar panels some time back and they have sat unused up til now. I woul dlike to use them to provide some night time LED lighting in the barn whare there is currently no power. Tell me how te get from the panels to battery to lights without spending a fortune. I already have a battery I can use.
Offline ljohnsaw
Re: Solar lights for the barn
« Reply #1 on: March 25, 2018, 12:47:58 PM »
You just need a charge controller.  You can find them on eBay for $15-25.  You want a PWM based module.  It will have a solar input, battery output and power output connections.  You need to run the heaviest wire you have from the panels to the controller (placing it as close to the battery(ies) as you can.  Generally, the panels will provide 20-30vdc at so many watts.  You need to match the controller to the volts and watts.  If you hook your lights to the power out on the controller (as opposed to the battery), the controller will cut off the power before the battery's voltage drops to a point that it would damage them.
John Sawicky
Offline LeeB
« Reply #2 on: March 25, 2018, 12:55:34 PM »
So, I would be better off to run the panels in series and have higher voltage to the controller and less amperage for my LED lighting scenario?
Offline ljohnsaw
« Reply #3 on: March 25, 2018, 01:09:09 PM »
It is going to depend more on how many amp-hrs you will need (total load and how big a battery bank).  In parallel, the two panels will charge you battery faster, in series, you will have less loss (can use smaller wire).  I would do in parallel so you are getting the most charge.
John Sawicky
Offline LeeB
« Reply #4 on: March 25, 2018, 02:10:25 PM »
If they are hooked parallel will they actually charge the battery enough since they are 12 volt panels? Enough to charge a two battery bank?
Offline 21incher
« Reply #5 on: March 25, 2018, 08:03:38 PM »
I have been using a renogy 100 watt panel for lighting my pole barn for several years. They have a good sale on charge controllers now and have wiring schematics on their site also. I have mine hooked up to one of their charge controllers and then 2 big deep cycle 12 volt batteries in parallel. I think the panel puts out 24 volts and the controller can handle a 12 or 24 volt system. I have a 700 watt power inverter that runs 3 of those 5 socket 50 ft temporary lighting power cords with 15 of the 23 watt 100 watt equivalent 110 volt cfl bulbs. I can get about 3 hours a day of light during the summer. Someday when the price comes down I will switch to led bulbs. I had a problem starting the cfl bulbs with a low cost inverter at first and had to step up to a better grade inverter to light them when it is cold out. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline ljohnsaw
« Reply #6 on: March 25, 2018, 08:21:00 PM »
What is the peak voltage on the label?  To charge a 12v battery, you need at least 13 to 13.5 volts.  If the peak is only 18 to 20v then they are "12v" panels.  A 24v system uses 30v panels.  If you hook the batteries in parallel, the voltage is still 12v but your amp hours goes up (longer run time).
John Sawicky
Offline LeeB
« Reply #7 on: March 25, 2018, 10:07:30 PM »
Can't sat what the peak voltage is from where I'm sitting right now. Once I get home I can take a look.  :D
Offline LeeB
« Reply #8 on: March 25, 2018, 11:40:50 PM »
Alrighty then. Looked up the specs for the panels I have and it says optimum voltage 18.9V and 5.29A. Guess that tells me what I need to know. Now on to researching what lights I want to use.
Offline ljohnsaw
« Reply #9 on: March 26, 2018, 01:59:38 AM »
OK, so you need to hook them up in parallel and they will deliver 10.6 amps. Get a controller that is good for 12 to 15 amps (or more).  The panels can actually do better then the rated amp in certain situations so go bigger then 10 amps.
Google is your friend.  You can find out how much power you will get on a typical day and use that to size the battery bank.  Remember to preserve your battery life, you only drain the battery to a certain level, never to dead flat.
John Sawicky
Offline LeeB
« Reply #10 on: March 26, 2018, 02:44:22 AM »
Yes sir, google does help a lot, but input from you has also helped by guiding me toward the searches I need to make. Thank you much.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #11 on: March 26, 2018, 10:10:18 AM »
My recent craze has been 12 volt offroad LED lights for floodlights on my house. I am using PC power supplies to power them off a standard 110 plug. The lights I found are available on amazon it was $20 for a 2 pack of 12" spot flood combo light bars. Makes the best flood lights I have ever had and the cheapest. May be worth looking into just running offroad LED lights direct off the battery.
The reason I went this route is due to the high cost of 110 powered LED floodlights.
Offline barbender
« Reply #12 on: March 26, 2018, 12:33:47 PM »
I geeked out on the 12 volt leds as well, I've been putting them on everything!
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #13 on: March 26, 2018, 01:14:39 PM »
I also bought a 10 pack of 4' led tubes to replace fluorescent lights. instead of putting them in fixtures I wired up a 6' pigtail to connect to the pins on the bulb and plug the other end direct into an outlet then hung them from the ceiling using a curved piece of romex as a hook.
This serves many purposes.
1. I gots me light for cheap.
2. did not have to deal with all the bad ballasts I had in my shop.
3. made the best drop light ever. I just reach up to the ceiling grab a light and poof instant drop light.
these bulbs are 110 variety but still almost no power draw and very reasonably priced about $12 per bulb.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #14 on: March 26, 2018, 09:31:49 PM »
How many lumens are they?
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #15 on: March 27, 2018, 07:41:20 AM »
I don't know I will have to look them up. If I ever get around to mounting them up on the soffit of the house they will light up my entire yard.
They work very well just sitting in the window.
Offline bodagocreek2
« Reply #16 on: March 27, 2018, 08:44:28 AM »
Like Barbender I use 2- 210 chip 12 volt led bulbs for a 24 by 32 shed. Bulbs have a screw in base like a regular bulb. Lights the whole shed up.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #17 on: March 27, 2018, 12:12:55 PM »
here is the lights I bought for floodlights
Liteway Pair 12Inch 72W CREE LED Light Bar Fog Light Spot Flood Combo Beam Bumper Lights for Car Truck Headlights Driving Work Light Waterproof for Jeep Offroad Camper ATV SUV 4WD, 2 Years Warranty
I lied the amazon price I paid total was $32.50
Offline Kbeitz
    • My Hobbies
« Reply #18 on: March 28, 2018, 04:28:32 AM »
Offline tawilson
« Reply #19 on: March 28, 2018, 04:51:10 AM »
This thread has enlightened me. Thanks. Never knew about LED fluorescent tubes .
2017 LT40HDG35 WIDE
Solar lights???
Started by Woodhauler on General Board
Last post July 11, 2010, 02:53:18 PM
by Magicman
solar/fiber optic lights
Started by Crunchycon on Alternative methods and solutions
Last post July 05, 2007, 11:16:15 AM
by Modat22
Red Barn, White Barn, Brown Barn, Blue?
Started by kwendt on General Board
Last post March 29, 2015, 03:50:59 PM
by Don_Papenburg
Timber-frame barn photo library and plight of the Mid-Western barn...of sorts.
Started by Rooster on The Wisconsin Barn Preservation Program
Last post November 14, 2009, 08:19:08 PM
by Rooster
