Tally-I/O
Author Topic: Danuser MD5 post driver  (Read 1925 times)
Offline CX3
« on: April 12, 2018, 11:31:48 AM »
I have an older yellow danuser free fall post driver. It's the one with the little rubber wheel that lifts the pounding weight. Well the rubber is shot and they want 320 for a new one. The way my mind thinks is I could wrap some good rubber belting around it and use an epoxy to glue it down. Clamped tight with hose clamps until dry. Tell me why this won't work or..... a better idea? I really don't mind buying the part but I really think I can fix it??
John 3:16
You Better Believe It!
Offline CX3
Re: Danuser MD5 post driver
« Reply #1 on: April 29, 2018, 10:16:10 PM »
Well in case anyone ever searches it......i bought some 1/4" thick rubber discs from sloan.com.   They were for a grain bin auger. Anyhow the discs were 6"diameter which was just what I needed. I punched a center hole with a chassis punch on an iron worker. You could use any hydraulic punch for that matter.
I then stacked all the rubber discs and clamped them tight. I marked the holes with the hub from the original friction drive. Drill press was a good choice here. Drill them 1/2" because the rubber closes after the bit is removed.
I then took all the discs and replaced them on the hub.
OEM parts cost was actually $385. I bought the discs online and had some time in them for about $159.  Worked like a champ.
John 3:16
Titan PGD3875 Gas Post driver
Started by LeeB on General Board
Last post October 25, 2018, 09:32:08 AM
by LeeB
smiley
New Driver
Started by Paul_H on General Board
Last post September 05, 2002, 07:40:12 PM
by Paul_H
Bobcat Stunt Driver
Started by Raider Bill on General Board
Last post July 28, 2013, 11:25:00 PM
by Bandmill Bandit
My First Truck Driver... My Friend...
Started by AlexInman06 on Forestry and Logging
Last post December 30, 2012, 08:43:50 PM
by Meadows Miller
