Author Topic: Moisture meters inside the kiln  (Read 699 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: April 28, 2018, 12:35:57 PM »
I operate a Nyle L53 Kiln, when checking the load on a daily basis i use my pinless wagner MM to check MC. Because I am inside the kiln (usually running around 120 degrees or higher) will that effect the reading of the meter? I have noticed a different reading on boards on the last day of drying versus when they come out of the kiln,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Moisture meters inside the kiln
« Reply #1 on: April 28, 2018, 07:55:43 PM »
My Wagner does not call for a temperature correction.  The Delmhorst J-2000X does require a temperature correction.
Offline Southside
« Reply #2 on: April 28, 2018, 10:05:14 PM »
Are your boards reading higher or lower the next day?  I was told to let the boards cool down and age "like a good steak" and then check the actual MC.  I use a Lignomat pinless and notice that the MC is lower after cooling.
Offline GeneWengert-WoodDoc
« Reply #3 on: April 28, 2018, 11:37:55 PM »
When you check lumber in the kiln during drying, it has a moisture gradient with the core being wetter than the shell.  So, the high core MC has more dominant effect.  Second, the meter is initially cool...cooler than the dew point... so condensation forms on the meter and gets into the electronics.  Neither a pin or pinless meter is designed to work with c0ndensation issues, so warm it up in a plastic bag before using it.  Third, the meter is calibrated for use at room temperature.  I have seen no indication that the meter itself is NOT affect by temperature; I have not seen where the manufacturer suggests that using a meter at 130 F or other temperature is ok...it is not.  So, I do believe a pinless meter should not be used on lumber with a gradient or used above room temperature (so, take the pieces out of the kiln for a minute at most).  A pin meter has the same equipment limitations, but at least Delmhorst and has wired systems and Lignomat has wireless probes that let the pins be in the kiln, but the measuring equipment is in a warm room.
Moisture Meter Readings Not Accurate Inside Kiln
Started by davemartin88 on Drying and Processing
Last post November 23, 2009, 02:30:28 PM
by Den Socling
Moisture Meters
Started by KiwiCharlie on Sawmills and Milling
Last post June 28, 2002, 07:01:22 PM
by KiwiCharlie
moisture meters
Started by Gary_B on Drying and Processing
Last post August 04, 2005, 09:25:18 PM
by Gary_B
moisture meters
Started by woodhick on Drying and Processing
Last post November 20, 2005, 07:03:53 PM
by Gunny
