Whatsitgoonabe?
Started by Jeff, May 29, 2018, 07:38:21 PM
Bruno of NH
Side boards for the truck ?
Nothing to do with Mr. Truck.
Put it up above your gate and then I'll tell you whatitis.
I just put a heavy coat of spar urethane on it. If it dries by tomorrow afternoon, it may begin to take shape.
POSTON WIDEHEAD
The proper orientation is a quarter turn clockwise.
Hilltop366
Looks like siding for a gable end of a building.
Quote from: Hilltop366 on May 29, 2018, 09:53:09 PM
That's a fair guess. :)
Southside
If you had said counter clockwise I might have guessed it was a boat transom.
White Oak Meadows
LAZERDAN
A big latch, for the gate on the new fence.
PAmizerman
I was thinking a valance for over a window. But it would need turned counter clockwise. Hmmm?
Hydraulics everywhere
Woodmizer edger 15hp electric
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
mike_belben
Kingsized headboard.
Praise The Lord
Ljohnsaw
A new mustache for the big statue of Paul Bunyan down in town. :D
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
There is one more key part to this that would give it away. :)
51cub
Whoever gets it right will be soaring with the eagles
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
It seems that some of yoozeguys know more than you are letting on.
low_48
WV Sawmiller
  Is it going to keep the robins from nesting where you don't want them? ;D
Ya know, it just might act as a Robin deterrent. Never thought about that.
JJ
Quote from: JJ on May 30, 2018, 09:46:43 AM
wooden eagle for USA
:) That was a fine guess there!
My spar urethane didn't dry last night. Its way to humid here. I probably won't get to due my assembly until tomorrow
