Author Topic: Resaws save time and money!!!!  (Read 2224 times)
Offline B@kerLuke
  • Board Moderator
« on: June 11, 2018, 05:27:00 PM »
With one of our Baker Horizontal Band Resaws, you could save a lot of time on breaking down cants and material, simply by having multiple heads and/or a return conveyor.  You may even be interested to know that we have a lazy susan style turn-around system that allows you to keep the resaw fed with minimal manpower!  And dont forget that the thin kerf of a band resaw brings a yield increase of at least 15-20% over a traditional circle blade!
Whether you are a larger operation and need multiple heads for single pass cuts, or a smaller outfit that needs a single head with return or turnarounds, we've got you covered!  Check out our extensive line of resaws and various options to fit your operation at Baker Products - Home.
Online Southside
    • White Oak Meadows
Re: Resaws save time and money!!!!
« Reply #1 on: June 11, 2018, 07:54:25 PM »
What's the longest length cant one can run on the lazy susan set up?
White Oak Meadows
Offline B@kerLuke
  • Board Moderator
« Reply #2 on: June 13, 2018, 10:52:25 AM »
The maximum cant you would want to run would be 60".
