Drying rate for Ginkgo 5/4
Started by Lopi, July 25, 2018, 09:43:20 AM
Lopi
Hi all,  I have milled a Ginkgo tree for a gal who wanted to re-purpose a tree that came down for house construction.  I have about 800 board feet of 5/4 to dry in a Wood Mizer KD150 (same as Nyle L53).  I'm guessing I can drying if aggressively as it is a very soft wood.  Does anyone know the max drying rate for Ginkgo?  Should I dry it like a softwood, or can I set the kiln for continuous run?    Thanks, Jeff
My instinct is to set the kiln for a continuous run.  It should dry like a softwood and it should dry fast.  But, I do not have any experience with ginko.
GeneWengert-WoodDoc
When we did not know what to do with an unusual species when I was at the US Forest Products Lab, we suggested the dogwood schedule.
Lopi
Thank you guys.  I went ahead with continuous run setting.  It had been shed drying for a few months.  I set the Wagner MM to a soft wood setting and it read 22% MC so I figured I'd be ok hitting it hard.  Thanks again.  Jeff.
