Author Topic: Yellow Birch  (Read 767 times)
Offline cbla
Yellow Birch
« on: September 07, 2018, 07:14:53 AM »
Does anyone know what caused these formations in this Yellow Birch Cookie. They run right through the 3 -  3inch cookies I cut off the stump of a 150+ year old Yellow Birch. The Tree was very healthy, with a beautiful crown.  It was removed for development reasons.
Thanks for any info!
Online Southside
Re: Yellow Birch
« Reply #1 on: September 07, 2018, 08:09:10 AM »
Clearly it has been promoted multiple times given the number of chevrons there.   ;D
Offline K-Guy
    • http://www.nyle.com/
Re: Yellow Birch
« Reply #2 on: September 07, 2018, 08:34:22 AM »
Obviously a working tree not like those lazy officer type trees. :laugh:
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline rjwoelk
    • countrysidefirewood
Re: Yellow Birch
« Reply #3 on: September 07, 2018, 05:58:23 PM »
It could be bark inclusion from it being 2 trees in one. I had a paper birch yesterday that is weird it had a crotch 16 ft away.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline cbla
Re: Yellow Birch
« Reply #4 on: September 08, 2018, 03:53:30 AM »
That is interesting rjwoelk.
Offline GeneWengert-WoodDoc
Re: Yellow Birch
« Reply #5 on: September 08, 2018, 09:43:58 AM »
The bird called the yellow-bellied sapsucker (and some other woodpeckers) will tap on the bark in order to cause the tree to bleed sweet sap, that attracts bugs and the bugs are just what the bird wanted.  Unfortunately, the bird sometimes taps too deeply and gets into the wood.  The injured zone in the cambium layers (the cambium layers are where new cells are made...wood to the inside and bark to the outside) do not know if they should make wood or bark.  They often end up making bark or even makes nothing for a few years.  Initially, the wound is large, but gets smaller each year as the tree grows larger...so we see a large wound area closer to the inside of the tree that quickly tapers as we go toward the bark.  The bird does make holes in uniform patterns, as can be seen from the bark oftentimes; so it is common to see multiple wound scars on a cookie.  Maybe someone has a picture of bark scars from multiple bird pecks...I am looking for mine.uuu
Online Southside
Re: Yellow Birch
« Reply #6 on: September 08, 2018, 11:00:23 AM »
Gene - do you mean the bulging saucer effect that is seen in pine?
Re: Yellow Birch
« Reply #7 on: September 08, 2018, 12:55:35 PM »
Do not know what you are referring to.
Online Southside
Re: Yellow Birch
« Reply #8 on: September 08, 2018, 03:29:19 PM »
I will get a picture
Offline cbla
Re: Yellow Birch
« Reply #9 on: September 08, 2018, 04:27:15 PM »
Interesting! Thanks Gene!
yellow birch
Started by redpowerd on General Board
Last post September 24, 2003, 06:16:38 AM
by woodmills1
Yellow birch
Started by wisconsitom on Ask The Forester
Last post March 18, 2019, 11:25:45 AM
by SwampDonkey
Yellow birch
Started by Bruno of NH on Sawmills and Milling
Last post August 07, 2018, 12:47:42 PM
by taylorsmissbeehaven
Sawing yellow birch
Started by jackpine on Sawmills and Milling
Last post January 31, 2007, 06:40:15 PM
by jpad_mi
