Dynamic Green Products Inc.
Author Topic: Fitting a tenon with a curved shoulder  (Read 960 times)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« on: September 15, 2018, 02:17:11 PM »
I've been working on a crib with curved pieces.  I realized very quickly that doing mortise and tenons would be a challenge.
I adapted an idea that I saw on YouTube from Charles Neil:
I made a sleeve that matches the curvature:
First I laid out the pieces, then I aligned a matching template and marked off where the centers are from the piece that needs tenons:
Then I carefully transferred the curve, at the proper orientation to the "sleeve", I fit two curved to the sleeve  one on each end.
Then I screwed the template to the top and bottom of the "sleeve", and used the bandsaw to rough out, and a flush trim bit to match everything up nice and flush.
Then I added spacers for the sides of the "sleeve", I used a strip of tape so that there is a little bit of clearance.
Then, trim that up, I accidentally blew out some end grain, but it should be ok.
I made a video of the same concept making tenons for an angled rail:
lots of dull bands and chains
Offline Dan_Shade
Re: Fitting a tenon with a curved shoulder
« Reply #1 on: September 26, 2018, 07:53:15 PM »
A few pictures of the finished product:
Offline Dan_Shade
« Reply #2 on: September 26, 2018, 09:52:10 PM »
Online Hilltop366
« Reply #3 on: September 27, 2018, 12:06:25 PM »
Slick, thank for sharing.
Tenon shoulder surface at post top to plate joint
Started by trouts2 on Timber Framing/Log construction
Last post September 18, 2018, 06:17:18 PM
by trouts2
Fitting joints
Started by Jim1611 on Timber Framing/Log construction
Last post December 14, 2014, 03:02:21 PM
by Dave Shepard
Test Fitting
Started by addicted on Timber Framing/Log construction
Last post October 31, 2015, 09:16:54 PM
by dean herring
Don't grease that fitting
Started by pnyberg on Sawmills and Milling
Last post July 16, 2011, 09:04:35 PM
by Don_Papenburg
