Best Big slab mill
Started by mmtrees, February 14, 2019, 11:21:39 PM
mmtrees
What is the preferred big slab mill?
Easy to setup and use?
terrifictimbersllc
What do you mean by a big slab?
DR Buck
I think you need to provide more specifics.    Aside from how big how much do you wan to spend?
Yeah... Best.....
Cut Size?
Cost?
Portability?
Speed?
Get different answers depending on your criteria.
Woodmizer make a big "headrig" that will slab up big logs a treat. Great machine, but it's neither cheap nor portable.
Lucas make a portable chainsaw slabber that can cut ~9ft wide. Not as fast as the WM, and a bit more kerf loss. Cheaper, more capacity, and more portable.
Most of the swing blade mills have very portable slabber options that clip on their regular mills for slabbing 5-6' dia logs. So you can have a machine that can cut boards OR slabs from oversize logs, AND can be carried on a pickup.
A bit more info about what YOU need to don will help narrow down what's best for YOU....
SawyerTed
Preferred?  I would prefer the WM1000.
longtime lurker
SawyerTed
Prefer is 100% subjective.....
Jack Lilley
JB Griffin
That mill is painful to watch. Feed rate of inches per minute.  :D
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Dave Shepard
Quote from: longtime lurker on February 15, 2019, 03:30:21 PM
Quote from: SawyerTed on February 15, 2019, 11:08:20 AM
Neah too slow.
Too slow compared to what other mill that can cut a five ton log that's 67" wide?
JRWoodchuck
Yoshihiro Sasada's mill cuts pretty quick and real big.
Home built bandsaw mill still trying find the owners manual!
